586,655 active members*
3,982 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Issues with soft wood on router table // End mill suggestions wanted
Results 1 to 7 of 7
    Mar 2019
    8
    Hey guys,
    Having some issues with milling this very, very soft wood on our router table.
    I am currently running a down cut, 2 flute carbide end mill @ 12k rpm and 80ipm (slowed down because of blowouts and still having issues)
    This is balsa wood, HAAS router table w/ vacuum and we do not have these issues with any other type of wood.
    looking for suggestions on end mills or anything I can do to help prevent these issues.
    Thank you!
    Cheers,
    Attached Thumbnails Attached Thumbnails IMG_20200304_110056.jpg   IMG_20200304_110100.jpg   IMG_20200304_110107.jpg   IMG_20200304_110133.jpg
    Mar 2019
    8
    Re: Issues with soft wood on router table // End mill suggestions wanted
    Looks like my attachments did no come through correct, here is a google folder with pictures.
    Cheers!
    https://photos.app.goo.gl/TXjD7gej9AJoqSbp7
    Aug 2005
    205
    No direct knowledge of cutting balsa on a CNC, but sharp tooling will probably be part of the solution. I would try HSS as opposed to carbide as HSS will present a sharper edge. Any sign of degradation in the cut warrants a change to fresh tooling. Also, single flute tooling??? Others will have to weigh in regarding feeds/speeds.
    Mar 2019
    8
    Hey Marv,
    Current Carbide tool seems pretty sharp still.
    All I have for HSS and Single flute end mills will be up cut, I'll throw them in and see what happens.
    My fear is that the up flute will make it worse and if im going to buy some end mills was hoping to get some hand on reviews.
    Cheers
    Mar 2019
    8
    And check the 2nd post for a google drive with the photos, not sure what happened to the original attachments
    Apr 2004
    5742
    Try new HSS cutters; they start out sharper than carbide (but don't stay sharp as long). Balsa is difficult to machine because while the fibers are strong, their attachment to each other is weak, so the material tends to tear out. Is that the only material that will work for your project? Paulownia is another wood you might consider; it's almost as light as balsa but not as stringy - it hangs together much better.
    Andrew Werby
    Website
    Aug 2005
    205
    Brandon,
    Make sure you're buying HSS router bits, not end mills. The geometry will be different. You may also want to see if Onsrud Cutter lists tooling for balsa in their tooling table (for feeds and speeds). My sense is there may be a very narrow sweet spot to accomplish what your trying to do. Let us know how it goes.
