586,036 active members*
4,437 visitors online*
Results 1 to 12 of 12
    Feb 2011
    138
    manual tool change
    I don't know how to achive manual tool change with tool measurement, tryed check box in Settings/tool change with no sucsses...
    Program pauses for x-time sec then go on. If I try to pause, then there is no possibility to click "tool measurement" button
    I have second input sensor configured on x,y pozition on table but, couldnt be reached - stoping program and clicking "tool measure" just go down on same spot, not moving to x,y position.
    Anny help desirable
    Feb 2011
    138
    Re: manual tool change
    Have just ansvered myself, must check all checkboxes in tool change menue!
    Now I have another problem, strange behavior during the mesuring tool lenght. Z-axes goes up fast, moves to x,y fast, Z goes down fast, then, goes up fast (to correct hight) and realy slowly down again.
    I thik, it shoud goes up, to x,y, position (fast), then it shoud decent certain amount (nice if can be adjusted regarding to hight of sensor) also fast, and only then, for a last few cm/in slowly.
    It will be also nice if the first tool change can be skipped assuming that first tool lenght is mesured with movable sensor (including table or material hight), all others tools shoud be mesured.
    rgds
    Mar 2017
    1312
    Send your profile to our support email.
    Mar 2017
    1312
    Set "Position Z" to same value as "Safe Height".
    Feb 2011
    138
    ok, I have change that, works as it shoud. Thank you!
    What abouth other two questions I have posted in e-mail? are they resonable?
    rgds
    Mar 2017
    1312
    I changed localization file if that is what you are referring to.
    Feb 2011
    138
    no, I am asking if is possible to have part of down movement of Z axes, just befor toucing sensor, max speed (amount shoud be input in mm/%/in regarding longest tool available), the last part f.e. 2-3cm as is now.
    This will speed up proces for mesuring specialy if safe high is qute high, and object are kinda 3d...
    Second question was if it possible to skip first tool mesurement regarding it has already be done when inserted the tool with movable sensor.
    Thank you for listening! Great Software! I lowe it more an more.
    Mar 2017
    1312
    New "Rapid Height" setting. Machine will move rapid from safe height to here
    Feb 2011
    138
    Wow! That is fast responce! I am werry pleased with solution. Just explain in "doc" the meaning of that.
    rgds
    Feb 2011
    138
    Assuming this will be implemented in next version.
    I have another suggestion, not really necessary but, more like wisual, the position of the second sensor (for tool measurement) in 3D wiew. It can be like a biger dot or cone or whatever.
    When running test program, can be wissible if the sensor is in working path.
    rgds
    Mar 2017
    1312
    How does this 3D tool sensor look to you? In will be in next version.
    Feb 2011
    138
    Perfect!
    Thankyou for listening!
    rgds
  1. Manual tool change TNG v2
    By tantemay in forum PlanetCNC
    Last Post: 06-16-2020, 10:29 PM
  2. HSK Style Tool Holder Manual Tool Change Spindles
    By tinmancarving in forum Spindles / VFD
    Last Post: 10-01-2018, 08:05 PM
  3. M6 for manual tool change
    By camivic in forum UCCNC Control Software
    Last Post: 12-10-2015, 12:25 PM
  4. Manual tool change and tool table help needed please
    By LEARN in forum Mach Software (ArtSoft software)
    Last Post: 06-10-2014, 09:31 PM
  5. manual tool change
    By Bruecher in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 08-30-2011, 11:36 PM
