586,121 active members*
3,432 visitors online*
    Indicators Calibration
    Firstly, I'm sorry that my english is not good.
    I would like to post an article regarding indicators calibration
    Newly purchased indicators or after a period of use should be calibrated.
    The calibration performed
    Check out.
    Technical inspection and measuring force
    Check measurement: check total errors, component errors and error recovery; repeatability test.
    Environmental conditions
    When performing the calibration, the following conditions must be met:
    For comparison meters with a value of 0,001 mm; 0.002 mm:
    + Temperature: (20 ± 3) oC;
    + Humidity: (50 ± 15)% RH.
    For a meter with a value of 0.01 mm:
    + Temperature: (20 ± 8) oC;
    + Humidity: (50 ± 20)% RH.
    Calibration Device Clock So
    Gauge Blocks.
    Pillar heaps of lakes.
    Force measuring device with division value ? 0.02 N or scale meter with division value ? 2 g
    For more details, please refer to this article: https://www.techmaster.com.vn/blogs/...uan-dong-ho-so (sorry it's not translated into English yet)
    Aug 2020
    Re: Indicators Calibration
    I think all of thing you need, you can find it from here: https://tktech.vn/dong-ho-do-quy-trinh-fluke-726/
    Apr 2023
    I think all of thing you need, you can find it from here: https://www.ndt-vn.com
    Jun 2023
    Your information is much needed and I will look into it in the near future.
    getting over it
  1. Mach 3 output indicators
    By Richster in forum Mach Wizards, Macros, & Addons
    Last Post: 11-05-2023, 09:06 PM
  2. Replies: 50
    Last Post: 04-04-2010, 06:33 PM
  3. Economic indicators - which do you use?
    By Chris D in forum Community Club House
    Last Post: 02-04-2006, 10:14 PM
  4. Proper use of dial indicators.
    By Cowbell in forum MetalWork Discussion
    Last Post: 01-23-2006, 11:37 AM
