586,116 active members*
3,372 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Gecko G540 multiple estop wiring diagram request
    Feb 2013
    81
    What would the circuit look like to wire two additional e-stops for a gecko g540 used in conjunction with Mach3? I have one on the controller box but need another two around the workshop. I’ve tried a few wiring variations out today but i’m flummoxed by this.
    Any links or diagrams most welcome.
    35538
    Re: Gecko G540 multiple estop wiring diagram request
    3 Normally Closed E-stops wired in series.
    Feb 2013
    81
    Correct. However when we wired a test NC E-stop after the primary it not triggering Mach3?
    35538
    Then you wired it wrong.
    If you have 3 normally closed switches in series, activating any one of them will open the circuit and trigger the input.
  1. HELP, mach throws up random ESTOP mid program. Gecko G540
    By dougie329 in forum Mach Software (ArtSoft software)
    Last Post: 12-04-2011, 07:35 PM
  2. G540 wiring diagram for dummies? :)
    By bkboggy in forum Gecko Drives
    Last Post: 08-28-2010, 07:45 PM
  3. Wiring diagram for Gecko g540 and cnc4pc C8 relay
    By blackrat in forum Gecko Drives
    Last Post: 04-25-2009, 11:22 AM
  4. need estop wiring diagram and how to for limit switches
    By eloid in forum CNC Wood Router Project Log
    Last Post: 11-06-2007, 03:55 AM
