586,655 active members*
3,352 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Non-circular boring. (Linuxcnc fun)
Page 1 of 2 12
Results 1 to 20 of 29
    Jul 2003
    1754
    Andy created a hex on his lathe by slaving his x axis to the spindle rotation. I wondered if I could do something similar on the mill....
    bore a hex hole anyone?
    I created a hal component (realtime module within linuxcnc) that takes the spindle angle and calculates where x/y needs to be to create a polygon. (hex in this case but you can do almost any sided polygon)
    Jul 2003
    1754
    Re: Non-circular boring. (Linuxcnc fun)
    testing the component...
    Jul 2003
    1754
    This machine is being run with a rpi4+mesa 7i92.
    working well so far.
    Jul 2003
    1754
    First couple tries in plastic. (painfully slow - just testing) (and the hole size should be way closer to the inscribed polygon diameter...)
    This is the hal component for linuxcnc... WIP use at your own risk.
    Code:
    //   This is a component for Linuxcnc HAL
    //   Copyright 2020 Sam Sokolik <[email protected]>
    //   This program is free software; you can redistribute it and/or modify
    //   it under the terms of the GNU General Public License as published by
    //   the Free Software Foundation; either version 2 of the License, or
    //   (at your option) any later version.
    //   This program is distributed in the hope that it will be useful,
    //   but WITHOUT ANY WARRANTY; without even the implied warranty of
    //   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    //   GNU General Public License for more details.
    //   You should have received a copy of the GNU General Public License
    //   along with this program; if not, write to the Free Software
    //   Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
    component polygon "Create a spindle synced motion that carves a polygon using eoffset inputs.  Assumes positive rotation.";
    pin in bit enable;
    pin in unsigned numsides=3 "Number of sides in the polygon";
    pin in float inscribedradius=1 "inscribed radius of the polygon";
    pin in float cutterdiam "cutter diameter";
    pin in float eoffsetscale "scale that eoffset is set to.";
    pin in float toolang "angle difference between index and actual tool poition";
    pin in float spindlepos "Spindle position scaled to 1 per rev";
    pin out float spindlerad "Spindle postion in radians";
    pin out float polyradius "radious of the polygon at given spindle position";
    pin out float xoffset "x offset to send to offset componant";
    pin out float yoffset "y offset to send to the offset componant";
    pin out signed xeoffset "x eoffset output";
    pin out signed yeoffset "y eoffset output";
    pin out bit isindex "set index enable only once";
    pin io bit indexenable "hooked to index enable of encoder";
    function _;
    license "GPL";
    #include  <rtapi_math.h>
    #define  PI 3.14159265358979323846
    float spinang;
    float scale;
    float spinangoffset;
        if (!enable) {
            xoffset=0;
            yoffset=0;
            xeoffset=0;
            yeoffset=0;
            isindex = false;
            return;
    // only set index enable once
        if (enable && !isindex) {
        isindex = true;
        indexenable = true;
            return;
    // wait for spindle index before actually enabling
        if (enable && isindex && indexenable){
            return;
    //convert spinangoffset to ratio.. for adding to spindle pos - plus a couple rotations
    //so the spindle position isn't negative
    spinangoffset = (toolang/360)+2;
    //formual I found is for circumscribed - convert to inscribed - makes more sense.
    scale=inscribedradius/cos(PI/numsides);
    spinang = ((spindlepos + spinangoffset) - (int)(spindlepos + spinangoffset))*2*PI;
    polyradius = (cos(PI/numsides)/cos((fmod(spinang, (2*PI/numsides))-PI/numsides)))*scale-cutterdiam/2;
    //actual offsets applied - could be used for offset componant.
    xoffset = cos(spinang)*polyradius * -1;
    yoffset = sin(spinang)*polyradius;
    //counts for use with eoffset functionality
    xeoffset = xoffset / eoffsetscale;
    yeoffset = yoffset / eoffsetscale;
    spindlerad = spinang;
    Jun 2010
    4256
    OK, that's a new one on me. Very clever.
    You need a servo-controlled spindle for it: mine cannot do that.
    Cheers
    Roger
    Jul 2003
    1754
    No... The axis are slaved to the spindle. You see me.turnung the spindle by hand and the 2 axis moving.
    Jun 2010
    4256
    Encoder on the spindle then?
    Cheers
    Roger
    Jul 2003
    1754
    Yes - exactly.
    Jul 2003
    1754
    Now rotatable...
    Jul 2003
    1754
    Added the ability to change the radius of the polygon by moving the X axis. (so you can create profiles..) The resolution of the spindle encoder is visible in the cut you could also just do round profiles. Sort of like lathe turning profiles on a mill.
    Jul 2003
    1754
    video coming... one gcode program - chamfer, hex and hole all poly-bored..
    Jul 2003
    1754
    another high quality video..
    Jul 2003
    1754
    surprised how well it worked considering what I am working with mechanics wise...
    Jul 2003
    1754
    Aluminum!!
    Jun 2010
    4256
    OK, aluminium: now seriously impressed!
    Cheers
    Roger
    Jul 2003
    1754
    And just to see if it could be done....
    Jun 2010
    4256
    Keep that up and fairly soon people will be refusing to believe the photos!
    Cheers
    Roger
    Nov 2012
    1266
    I've seen THAT shape before.
    Jul 2003
    1754
    Pay no attention to the man behind the curtain....
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    Jul 2003
    1754
    Lathe mode
    - - - Updated - - -
    start at upgrading the spindle encoder...
    https://youtu.be/VmWeXS6y-lg
Page 1 of 2 12
  1. Replies: 0
    Last Post: 10-31-2019, 05:13 PM
  2. Replies: 0
    Last Post: 07-29-2013, 01:15 PM
  3. Replies: 0
    Last Post: 07-24-2013, 07:03 AM
