Does anyone know the M code to get the high-low clutch on a FX25 to change? I can get it to change using the manual controls but not in a program. A 1500 rpm speed will stay in high when given a 200 rpm command. The spindle will slow down to the commanded speed but, will stay in high range. I need a shift for the torque. I'm thinking an M code for the range shift? The control is a Fanuc 5T Thanks db
