586,068 active members*
3,881 visitors online*
    Drip Feeding with Fanuc 6mb-2
    I have a Excell-O 1987 with Fanuc 6mb-2 controler. It equiped with a tape reader than we not use.
    Can we bypass this tape reader to plug the RS232 in some manner?
    Can we have the procedure somewere?
    Is it a obligation to have something like «Behind Tape Reader» (BTR).
    Tank for responses!
    Stéphane Jacques (French canadian, sorry for my english )
    Sep 2005
    767
    The best way to to run a Fanuc 6M from a PC is to use the tape reader (BTR) connection. There are two ways to do this:
    You can connect a parallel BTR cable directly from the Fanuc mother board to a PC's parallel printer (LPT) port. This requires a special parallel BTR cable and special software for the PC. The main disadvantage to this method is that the BTR cable cannot be very long, so the PC must be within about 10 feet of the CNC control.
    You can also install a BTR board, then run a serial cable to your PC. This method is more costly, because you need to buy the board, the serial cable, and also some DNC software for the PC. The main advantage to this method is that the cable to the PC can be much longer.
    We offer both types of BTR connections. Please contact our distributor, Refresh Your Memory, Inc. for more information. Their website is www.rym.com
    hello i am trying to load factory parameters on a hitachi seiki w/fanuc 6mb through a tape drive and i have never seen a tape reader before any suggestions
  1. Drip Feeding to a Fanuc 6m
    By TR MFG in forum Fanuc
    Last Post: 09-01-2017, 06:51 PM
  2. Drip Feeding
    By widgitmaster in forum Polls
    Last Post: 01-28-2011, 09:02 PM
  3. drip feeding problem
    By yoya in forum DNC Problems and Solutions
    Last Post: 07-07-2006, 06:33 PM
  4. Drip Feeding a Fanuc 6M B "Trouble"
    By Scott_M in forum Fanuc
    Last Post: 05-12-2006, 02:40 PM
  5. Drip Feeding To a Brother (TC-218)
    By Igot2drip in forum Uncategorised MetalWorking Machines
    Last Post: 03-15-2004, 05:50 PM
