Hello sir,
The Leadshine LD5-400 DC Servo Drive is not working in jog run mode. I m using the 3phase servo motor
Motor Details:
Voltage: 36v
rpm: 3000rpm
power: 200watt
motor is with gear
i connected uvw wires and encoder cable of motor to the ld5-400 drive and connected 36v power supply to driver.
i tried running the motor but every time it gives the same error
error1: 1A1 (which means com- is not connected)
error1:100 (overload), but i have not connected any load. i have set all the parameters required for jog run mode in the user manual provided by leadshine. i tried running using protuner software but was not successful.
please help me to solve this problem
