586,055 active members*
4,311 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > Leadshine LD5-400 DC Servo Drive not working in jog run mode
Results 1 to 8 of 8
    Mar 2020
    4
    Hello sir,
    The Leadshine LD5-400 DC Servo Drive is not working in jog run mode. I m using the 3phase servo motor
    Motor Details:
    Voltage: 36v
    rpm: 3000rpm
    power: 200watt
    motor is with gear
    i connected uvw wires and encoder cable of motor to the ld5-400 drive and connected 36v power supply to driver.
    i tried running the motor but every time it gives the same error
    error1: 1A1 (which means com- is not connected)
    error1:100 (overload), but i have not connected any load. i have set all the parameters required for jog run mode in the user manual provided by leadshine. i tried running using protuner software but was not successful.
    please help me to solve this problem
    Nov 2013
    4373
    Re: Leadshine LD5-400 DC Servo Drive not working in jog run mode
    you have connected the U,V,W wires, are they in a plug?. It may be that the servo is turning the wrong direction relative to the encoder.
    If that the case just swap any two of U,V.W.
    Craig
    Mar 2020
    4
    Thanks for the suggestion Joeavaerage sir,
    U,V,W wires are not in a plug. I tried swapping the U,V,W wires but again the same error.
    Nov 2013
    4373
    you should only swap two wires, say leave U where it is and swao the other two.
    Craig
    Mar 2020
    4
    Hello sir,
    yes i did the same thing. i swapped the V,W wires. the error is 100(overload)
    Nov 2013
    4373
    sorry I am not familiar enough with Leadshine servos to be of any help, I use Delta servos.
    Craig
    Mar 2020
    4
    hello sir,
    it's ok thank you.
    May 2015
    38
    Hi ManjuHBR, thank you for supporting Leadshine products.
    The motor phase UVW must be corrected to the drive LD5, do you have motor datasheet and where did you buy the low voltage servo drive LD5-400?
