586,112 active members*
3,138 visitors online*
    Dec 2005
    9
    newb question - machine all wired up - doesn't move
    I'm trying to get my home made cnc router working. I'm using Mach4 with a PMDX 424 SmartBob-USB motion control board and Gecko Drivers. When I input a simple command like G1Y1. into mach everything seems to work correctly with mach and the motion control board. Mach counts up on the correct axis and the motion control board step led flickers so it seems to be receiving the move command and as far as I know its outputing it as well. However I don't get any movement on my stepper motors. The wiring all seems correct. Not sure what to try next. I'm running Windows 7, 64 bit with 8GB of ram. 640 oz-in steppers and power supply wired for 110 volts.
    Jul 2018
    6341
    Re: newb question - machine all wired up - doesn't move
    Try a bigger move and check your steps per unit are correct. Peter
    Nov 2013
    4376
    are the stepper drivers enabled?
    Craig
    1228
    Check that the wiring to the steppers is correct.The OP doesn't say how many pairs of wires are coming out of the steppers or what process was used to determine which pairs were part of the same circuit.Without intending to cast aspersions i would be curious to know if undiagnosed colour blindness may be a factor-could be worth getting checked out.
    Dec 2005
    9
    I had the wires at the SmartBob-USB connected incorrectly. After redoing, I have movement. Thanks all for your responses.
  1. 6525A suddenly doesn't move x z y axis
    By lasergraphotero in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-04-2016, 08:24 AM
  2. Tailstock quill doesn't move
    By wiker in forum Uncategorised MetalWorking Machines
    Last Post: 08-18-2015, 12:51 AM
  3. Replies: 9
    Last Post: 12-29-2014, 05:36 AM
  4. part to long for machine (Newb question)
    By Oldstairdog in forum Uncategorised CAM Discussion
    Last Post: 11-02-2014, 07:30 AM
  5. Simple (dumb?) question . . .Machine move
    By brgrii in forum Uncategorised MetalWorking Machines
    Last Post: 04-17-2007, 09:51 PM
