586,076 active members*
3,802 visitors online*
Results 1 to 9 of 9
    Apr 2013
    110
    Crash TNG with V. 14/03/2020
    after updating to V. 14/03/2020 every time I try to access the settings, TNG goes into crash and closes; consequently I cannot update the firmware (normally MK3 is connected in LAN and the firmware can be updated only with USB but without accessing the settings I cannot change the type of connection). Only by installing another TNG in another location I was able to update the firmware but in any case every time I try to access the TNG settings it closes.
    Everything seems to work except for access to settings and licensse menagement.
    Apr 2013
    110
    Re: Crash TNG with V. 14/03/2020
    If it can be useful ... about a month ago I changed PC but not later than two days ago (V. 12/02/20) I was able to access the settings without any problem.
    Mar 2017
    1312
    Which one crashes? "License Manager/Licenses" or "License Manager Activation Code"?
    I will make firmware update possible without going to setting to change to USB.
    Jul 2016
    108
    Hi there, try to reduce transferring speed rate and finally Gatter earth wires to one poind to ground. Also check if the your system version is supported the relas4d updated framework for your new frimeware.
    Best regards
    R.teimouri840
    Apr 2013
    110
    TNG closes when I click on the selected items.
    Apr 2013
    110
    [QUOTE]Which one crashes? "License Manager/Licenses" or "License Manager Activation Code"?[/ QUOTE]
    both
    Mar 2017
    1312
    Clicking "License Management..." just shows submenu. And it crashes?
    Can you export and send me your profile.
    Apr 2013
    110
    [QUOTE = PlanetCNC; 2362874] Facendo clic su "Gestione licenze ..." viene registrato solo il sottomenu. E si blocca? [/ QUOTE]
    Sì.
    Ho riscontrato un altro errore durante la modifica manuale di uno strumento ...
    ... Another thing, even when exporting the TNG profile, it closes and does not save the profile. I had to do the manual zip.
    Apr 2013
    110
    I solved the CRASH problem in the "settings" menu and in the "License menagement" submenu by inserting an exception in the Windows Firewall as shown in the image below.
    I ask PlanetCNC if they can please add "SOLVED" to the discussion title.
    Thank you
  1. [TNGv2] - 2021-10-08
    By PlanetCNC in forum PlanetCNC
    Last Post: 10-11-2021, 08:17 PM
  2. Top 11 CNC Routers 2020!?
    By burs in forum DIY CNC Router Table Machines
    Last Post: 06-01-2020, 05:52 PM
  3. 2020-01-17 download?
    By theRat in forum PlanetCNC
    Last Post: 01-17-2020, 09:42 PM
  4. 1.2020
    By Gallchobhair in forum UCCNC Control Software
    Last Post: 09-27-2016, 07:28 PM
  5. Rutex 2020 card
    By johnd in forum Servo Drives
    Last Post: 01-18-2008, 01:43 AM
