586,111 active members*
3,242 visitors online*
Results 1 to 10 of 10
    Mar 2008
    375
    Whitworth form thread
    got a question maybe someone can help
    55 degree vs a 60 degree thread
    does anyone still do 55 degree thread?
    Nov 2013
    4376
    Re: Whitworth form thread
    unless its a really critical high torque/load thread who cares? The only thread for which there is a clash between UNC and BSW is at 1/2 inch,
    the pitches are different.
    Craig
    Mar 2014
    4
    The difference is geometry.
    Mar 2020
    22
    It's not a matter for strength - or rather a 60 degree PA nut if fitted on a 55 degree PA bolt would hold well enough for most purposes. Consider bearing: the line bearing of the 60-degree crest to the 55-degree root would lead to instant galling. The whole idea of matching pressure angles is to ensure and area bearing. There is always some mismatch the bearing is never perfect but metal is also a little forgiving. It will deflect and flow to a microscopic extent but not much; certainly not 5 degrees.
    If you can't think the problem through in a technical sense, try personally.
    Fitting Unified or DIN(?) 60-degree threads to 55 degrees Whitworth is a classic "a guy ole me.." piece of technical idiocy. I'm surprised anyone would seriously consider it - which is a caveat to noobs. Not everyone in an assured manner is worth listening to.
    Mar 2008
    375
    thank you for the replies
    so i have been looking for a 2 1/4 x 4 tap and for some reason nobody sells them does some know where i can get one?
    thank you
    Nov 2013
    4376
    a 2-1/4 tap will cost a fortune even if you can get one. Not to mention the huge torque you be required to apply to cut the thread.
    Can you not cut it on a lathe or mill it?
    Craig
    Jul 2018
    6341
    Hi Cob - Do you mean a 2-1/4" diameter 4tpi tap in whitworth? Peter
    https://wallersindustrialonline.com/...RoC3qwQAvD_BwE
    try these guys Peter
    or these in USA - they have 2-1/4x4 tpi in their catalogue
    https://www.newmantools.com/taps/tapsbritish.htm
    15362
    Quote Originally Posted by cob View Post
    If you have a need or are repairing something then yes anything you want is available I have threading inserts for 55 degree thread cutting and most manufactures still make 55 degree carbide threading inserts and Taps
    If you have something that has a 55 degree thread then you will have to make the matching part or make both parts with 60 degree threads
    Mactec54
    Mar 2008
    375
    thank you guys for all the sudjestion
    ( 2-1/4" diameter 4tpi tap in whitworth) yes this is the whitworth thread .
    yea I dont think i will be buying a tap, its to expensive,
    my next question is do you guys know if theres a place that sells nuts that are already threaded to 2-1/4 x 4tpi?
    thank you
    15362
    thank you
    This company may be able to help they have those big sizes will most likely have to make it
    https://www.lawsonproducts.com/catal...jsp.sortByForm
    Mactec54
  1. Correct Method to Form Lead Thread?
    By FredSWUG in forum MetalWork Discussion
    Last Post: 01-06-2016, 07:33 PM
  2. Square Form thread
    By djm77 in forum Haas Lathes
    Last Post: 04-20-2012, 05:50 PM
  3. Thread cutting tool form
    By leeharrysouth in forum MetalWork Discussion
    Last Post: 12-05-2008, 11:07 PM
  4. Roll form thread die wheel question...
    By niggle in forum MetalWork Discussion
    Last Post: 06-11-2008, 06:10 AM
  5. Metric thread form tap, drill chart
    By conceptmachinin in forum MetalWork Discussion
    Last Post: 08-27-2007, 10:31 AM
