If you have a clamp on ammeter, prefereably AC/DC like the attachment type, work through the distribution and take readings at different points to pin-point the source of high currrent, for e.g. , take a reading on the 3ph input to the drive etc. It has to be a circuit that normally takes high current otherwise a fuse would have blown, control etc.
If it shows that the SP drive is reading high, disconnect the SP motor and test again.
Al.
Albert E.
