This CNC wood lathe knife is a new design carbide wood lathe cutter, it is used with CNC wood turning lathe machine, reduces the tool changing times greatly during one day working. This carbide lathe knife eliminates the need for frequent sharpening which is very common in lathe turning woodworking
Details for Carbide CNC Wood Lathe Knifes:
Knife holder: 40Cr Steel, size 20*20*150mm or 25*25*150mm
Knife blade: high quality solid carbide
Blade length: 40mm
Cutting angle: 17 degree
Blade tip radius: 0.75mm or 1mm or 1.5mm
Blade thickness: 13mm
Blade Hardness: 91-91.5 HRC
For more information: https://www.cncsparetools.com/produc...r-machine.html
