586,069 active members*
3,877 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > 16mm Pillow block on 5/8 Thomson rails
    Jun 2007
    74
    I have a set of two beautiful 5/8 (.625") Thomson hardened steel rails 3 feet long. They would normally use the SPB10-opn linear bearings, which are quite expensive. I have found 16mm open bearings online which is .629" for significantly less cost. Do you think this would be suitable on a metal cutting CNC mill build? My gut says yes, but I would like to hear from other experts. I can purchase these 16mm in either steel circulating ball bearing or a hard polymer. The polymer is more expensive. I am unsure which is best or if it is even an option.
    I already have one metal cutting CNC machine with the proper bearings, but I'm thinking of building another with my extra rails.
    Thanks.
    Nov 2013
    4373
    Re: 16mm Pillow block on 5/8 Thomson rails
    using 16mm bearings on 5/8 rails will result in lash, a definite no-no in CNC.
    Are theses rails round? End mounted round rails are way to flexible for a mill. Square rails bolted every 2-4 inches to an absolutely rigid
    bed is required for metal cutting machines.
    Craig
  1. Ball screws & linear rails.
    By diyengineer in forum Want To Buy...Need help!
    Last Post: 03-10-2010, 02:56 AM
  2. Left hand, Metric Ball screws?
    By fatal-exception in forum Linear and Rotary Motion
    Last Post: 09-03-2009, 10:47 PM
  3. Metric or Imperial Ball Screws
    By chris1407 in forum Australia, New Zealand Club House
    Last Post: 08-07-2007, 11:59 PM
  4. Sources for new BIG ball screws and rails?
    By ewest in forum Linear and Rotary Motion
    Last Post: 05-21-2007, 04:56 PM
  5. Is it legal to mix inch and metric ball screws?
    By dmgdesigns in forum DIY CNC Router Table Machines
    Last Post: 04-13-2004, 05:52 PM
