586,108 active members*
3,084 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Find M-Codes in PMC-L ladder dump?
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Re: Find M-Codes in PMC-L ladder dump?
    If you go to coil Y48.4 in your ladder and scroll up you will come across a function block SUB9 COM. What this function block does is set all the coils to OFF between the SUB9 and SUB29 COME (COM END). If you scroll down you will see SUB29. Your clamping circuit is between these two SUBs. If SUB9 is on the logic works as if you didn't use COM in the first place. You will have to verify that COM is on when you are trying to clamp.
  2. #22
    Dec 2005
    504
    Quote Originally Posted by drdos View Post
    I think the output port check Y48.4/Y48.5 in N00253 and N00254 was canceling itself out. Does this look workable?
Name:	Screen Shot 2020-03-27 at 6.41.56 PM.jpg
  3. #23
    Dec 2005
    504
    Mr. Yasuda caught a typo in N00253. He said with the fix the ladder should work. I'll burn new eproms and give it a go on Monday.
    Attachment 439222Attachment 439224
  4. #24
    Dec 2005
    504
    It works! The foot pedals works, the m-codes work, it all works!
    Thank*you for all your help and patience.* I have learned so much.*
    I would like to especially like to thank, Dalvi of https://www.indiamart.com/cnctek-engineers/ for making binaries with his HI-ROM, I couldn't even have started without his help. And Mr. Yasuda of https://www.pmcladder.com/ for reviewing my ladder when I was really stuck. Prior to this I had never read an eprom let alone even seen a ladder. Thank you to everyone here on cnczone who took time to help me understand what was needed and keep me pointed in the right direction. I have learned a lot and it's been quite fun. Thank you again.
  5. #25
    Aug 2008
    13
    it was my pleasure helping you out.All the best.
    Dalvi
  6. #26
    Sep 2021
    43
    DEAR SIR.
    I AM NEW MEMBER, CAN YOU SHARE ME THE INSTRUCTION FOR UPLOADE AND EDIT THE LADDER ON FANUC O-T.
    THIS IS MY EMAIL: [email protected].
    I AM VERY GRATEFUL FOR YOUR HELP.
    BEST REGARDS.
Page 2 of 2 12
  1. Dmh-400 ladder without pallet magazine ladder?
    By dpionk in forum Daewoo/Doosan
    Last Post: 04-22-2015, 06:22 PM
  2. ZT1500Y M codes and ladder logic
    By Kwi4137 in forum Mori Seiki lathes
    Last Post: 07-03-2013, 04:50 PM
  3. Replies: 20
    Last Post: 12-19-2012, 07:35 AM
  4. G codes and M codes for Mazak Quick Turn T-2
    By sauli in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-23-2011, 05:22 PM
  5. Anybod have a jetmatic Or know where I could find a manual of the codes?
    By madman270 in forum Uncategorised MetalWorking Machines
    Last Post: 10-31-2010, 02:49 PM
