586,115 active members*
3,450 visitors online*
Results 1 to 7 of 7
    Apr 2012
    161
    What are rings from SuperSpacer
    These rings came with my Tormach SuperSpacer 6". I have no idea what they're for; there's nothing in the operator's manual. Anyone know?
    Attachment 438736
    "You can't teach stuff in a school that you would learn in real life unless the real life people are in charge of the school." - Gene Sherman
    Apr 2013
    1788
    Re: What are rings from SuperSpacer
    I don't have a super spacer but I believe that those are masking disks for the 24 position indexing plate. Search the Practical Machinist website for "How to Mount a Masking Plate/Super Spacer" or try https://tinyurl.com/wyb7kad
    Aug 2009
    1573
    from left to right.. the 1st Index ring is 90 degree...2nd is 45 degree.. 120 next...180 next
    Apr 2012
    161
    I see. So you'd use those if you were using the SuperSpacer manually and not controlling with CNC.
    Apr 2013
    1788
    I believe that that is correct.
    Nov 2007
    2151
    Quote Originally Posted by scott216 View Post
    For no particular reason I installed the blank one "no notches" that way the lock has no place to lock. Not installing one at all does the same thing and I don't think the lever can engage anything to damage the unit either way.
    673
    Those plates predate cnc, but when doing production and drilling holes at standard increments, you can do it super fast manually. If your super spacer isn't CNC driven, they are still super handy for that purpose.
  1. 8" SuperSpacer Sprutcam setup
    By s2jesse in forum Tormach Personal CNC Mill
    Last Post: 12-24-2015, 09:49 PM
  2. Distance rings?
    By zephyr9900 in forum Tormach Personal CNC Mill
    Last Post: 05-30-2012, 02:46 AM
  3. Rings around job in mach3?
    By daz59 in forum Mach Software (ArtSoft software)
    Last Post: 08-01-2011, 01:19 AM
  4. O-RINGS REPLCEMENT
    By CHANDRU in forum Mechanical Calculations/Engineering Design
    Last Post: 07-19-2010, 04:09 PM
  5. Boring Rings U.K.
    By bugdog in forum Want To Buy...Need help!
    Last Post: 01-25-2010, 11:56 PM
