586,043 active members*
3,731 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma OSP-U100L Add Serial Channel
    Question Okuma OSP-U100L Add Serial Channel
    Good afternoon, my name is Diego and i work as automation engineer. But right now my company is working on a project with Okuma CNC. There is a company with serveral Okuma CNC, a wheel factory, and we are installing a gauge on each one. This gauge measure the wheel height, to make a compensation, the project was already started, so we only are finishing it. The measure is done by a Marposs Gauge, conected to a EZ-Comp that works as CNC-Gauge interface. The last device talk to the Okuma by RS232 serial. And we have finished two of them. In one of the Okumas we had problems with the channel 0, even when the parameters was the same as the fiirst one, so we changed the communications to Channel 1, and it worked properly. Right now we are having troubles whit a third one, but this only have one channel, 0, so we are triying to add a RS232 card, to add new channels, but we dont know how to enable them on the parameter list. We still have only one channel. Is there a way to add them. The card that we are adding is A911-2913. Thanks for your help.
    Apr 2009
    1262
    Re: Okuma OSP-U100L Add Serial Channel
    You would need new software to enable the additional port.
    That being said , make sure that after you change settings that you wait 2.5 min for complete backup and then power off including breaker for about a minute to let the RS board properly reset to the new settings.
    Experience is what you get just after you needed it.
  1. Okuma LB300///OSP U100L
    By iffe123 in forum Okuma
    Last Post: 08-25-2023, 04:30 PM
  2. OKUMA OSP-U100L G42 inside G81 issues.
    By rago0 in forum Okuma
    Last Post: 11-24-2016, 04:41 AM
  3. Okuma OSP U100L serial on a LB300
    By fomaz in forum Okuma
    Last Post: 04-24-2013, 06:59 AM
  4. Okuma Lathe LU15/OSP-U100L
    By edirig1 in forum Okuma
    Last Post: 12-07-2010, 01:48 AM
  5. Replies: 6
    Last Post: 12-03-2007, 01:32 PM
