586,069 active members*
3,446 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Does anyone know this stepper motor?
Results 1 to 10 of 10
    Apr 2015
    4
    I've looked everywhere. I can't find the datashet Do you have any guidance for me?
    Please
    Nov 2013
    4373
    Re: Does anyone know this stepper motor?
    what you you need from the spec sheet?
    Is there something about the stepper that you cannot measure or otherwise deduce?
    Craig
    It look llike that motor from China , do you want to get a new pcs one ?
    Nov 2013
    4373
    Rubbish, it is a two phase Vexta stepper made by Oriental Motor Co, Japan......its as good as stepper motors get.
    My mini-mill is powered by Vexta 5 phase steppers and ultra low lash planetary gear reductions and Vexta drives....all absolutely superb.
    Craig
    Apr 2015
    4
    Thank you for your help.
    I need to change this engine, and I don't know which features to analyze for the purchase ..... What should be analyzed to buy an exactly identical engine
    Nov 2013
    4373
    Why? Vexta steppers are class leading quality, if its not broken then is there need to change it?
    Steppers follow NEMA size recommendations. Is it a 17 size, 23 size, 34 size? By that I mean 1.7 (or 2.3 or 3.4) inch across the flats
    of the mounting flange? Thereafter just about any stepper will work. If you want to use it for CNC purposes and therefore want it to run
    fast then you MUST select a low inductance replacement.
    Craig
    Apr 2015
    4
    The stepper motor is defective so I must replace it.
    But there are other parameters besides their dimensions, such as torque, phase, number of wires, pitch. Or not?
    24221
    The spec's on the motor will get you started, volt/current , the No. of wires is 4 for Bi-polar, more than 4, Unipolar.
    I have the Vexta Cat. going back to 1994/95 but does not show that model.
    Al.
    Albert E.
    Apr 2015
    4
    Thanks,,,, AL
    What characteristics should I observe to choose an equal step motor?
    24221
    It is a little hard without knowing the full specs of the motor, but there are guides on the Gecko site that may be of help.
    Al.
    Albert E.
  1. Connect an 8 wire stepper motor to a TB6560 Stepper motor driver
    By muldoon22 in forum Stepper Motors / Drives
    Last Post: 12-31-2016, 07:26 AM
  2. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
  3. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  4. Integrated stepper motor? with built-in stepper motor driver
    By uirobot in forum News Announcements
    Last Post: 06-07-2010, 09:59 AM
  5. Beltdrive-stepper motor-stepper motor driver
    By Georg in forum Stepper Motors / Drives
    Last Post: 10-16-2007, 10:56 PM
