586,106 active members*
3,167 visitors online*
    Oct 2019
    Type 45 bearing question
    Hi
    I'm currently in progress of converting my 45 type mill to cnc.
    First axis to be converted is the z-axis. I use 20mm ball screws and therefore FK15 bearing supports which I converted to angular contact bearings.
    I only use one fixed bearing support at the top of the collum ==> no lose bearing support at the bottom.
    During assembly I noticed that the not supported end of the spindel can be moved by hand in radial direction.
    Is this normal? Can this be harmful to my ball screws?
    Thanks!
    Lukas
    May 2008
    1185
    Re: Type 45 bearing question
    That is fine.
    If your ball screw nut has slop you will be able to move the screws around. If its tight it will have almost no movement. Having a bearing on that end wont change the backlash or performance if you top rapids are under 200 IPM.
    youtube videos of the G0704 under the name arizonavideo99
  1. Replies: 2
    Last Post: 07-23-2015, 05:53 AM
  2. Replies: 0
    Last Post: 05-08-2013, 09:01 PM
  3. Bearing type for screws
    By sgalway in forum Benchtop Machines
    Last Post: 01-28-2011, 07:02 AM
  4. What is 4th or 5th axis bearing type ?
    By bigg in forum Mechanical Calculations/Engineering Design
    Last Post: 10-03-2006, 07:54 PM
  5. Bearing type?
    By CNCgr in forum Mechanical Calculations/Engineering Design
    Last Post: 02-23-2006, 10:35 PM
