586,114 active members*
3,200 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G0704 Motor doesn't turn on NEED HELP
    Mar 2020
    When I turn on the machine the spindle speed indicator reads 0 and when I turn the spindle speed adjustment knob nothing happens. Note, I have taken off the safety guard and hard wired the switch to permanently stay on. The spindle turns freely by hand with no noticable issues and displays the spindle speed when doing so. Both fuses on the back are good. The mill hasn't been used for any heavy duty use. Any help is greatly appreciated!!!
    May 2008
    1185
    Re: G0704 Motor doesn't turn on NEED HELP
    You need to close the splash gard...:banana:
    youtube videos of the G0704 under the name arizonavideo99
    Jan 2018
    1516
    Quote Originally Posted by Blakeo44 View Post
    Must be an issue with your wring. If you spliced it it might be in the 'guard open' position.
    Mar 2020
    Quote Originally Posted by dazp1976 View Post
    When the guard is open, the switch disengages power so I just hard wired it close. Has never been a problem since doing it. Has to be something else. Following the wiring diagram I can't find anything out of the ordinary either.
  1. G0704 Belt conversion Complete - Motor doesn't move
    By Ambico in forum Benchtop Machines
    Last Post: 01-23-2020, 07:42 PM
  2. M5 doesn't turn off spindle
    By ptoro01 in forum Mach Software (ArtSoft software)
    Last Post: 12-30-2018, 03:12 AM
  3. spindle doesn't turn
    By The_caveman in forum Spindles / VFD
    Last Post: 06-04-2016, 05:41 PM
  4. X6-1500gt Doesn't turn ON, Need help?!
    By KoenPepping in forum Chinese Machines
    Last Post: 03-23-2015, 08:27 PM
  5. X-axis motor doesn't turn, it's blocked all the time - how can I fix that?
    By Klausb in forum Machines running Mach Software
    Last Post: 05-13-2013, 09:05 AM
