587,040 active members*
2,874 visitors online*
Results 1 to 9 of 9
    Feb 2007
    67
    Macro B installed?
    Is there a quick, easy way to tell if Macro B is installed on a 6T control? How about a 10-11-12T?
    Thanks...
    Jan 2007
    91
    try this in MDI mode...
    #1=1;
    if it accepts this input. then you have the option.
    May 2007
    1003
    Don't forget to make sure the value stays in the control when the reset key is hit. I had an OT and an 18T control that excepted inputs, but the parameters that cleared the variables by the "Reset" buttom & M30 weren't set properly. Hitting the reset key so a tool could be rerun resulted in a clean slate.
    Mar 2005
    988
    That's why you use common variables and not local variables if you need values that "stick". Most machines will dump local variables or have it unrecognized after reset or M30. This keeps you from from stacking values when nesting locals to more than 1 level. Many machines can nest locals from 3-8 levels deep... you'll run into all kinds of problems if it "stuck".
    It's just a part..... cutter still goes round and round....
    May 2007
    1003
    Quote Originally Posted by psychomill View Post
    Thanks for the additional information. Up until a couple months ago all my programs were written using #500-#531. I tried to keep a set range for a specific use. Ran out of variables. So I decided to use that series only for controling such things as diameters, groove widths, etc. I chose to use the #100-#149 macros for use in my master and subprograms because it looked to me like the other variables are used by the canned cycles, and the G65 macro program calls that are used by Hardinge for such things as deep drilling.
    I am only just beginning to have an understanding of how they nest. Not nearly enough to use them. Besides, I don't think I will need them for the kind of parts we make. I only program for lathes.
    Knowledge is always a good thing, & often in short supply. Thanks.
    Mar 2005
    988
    #100 - 149 can be set to "stick" or dump. If you have a FANUC control and someone is willing to share the info, a parameter can be changed so that you can enable the Extended Variables option (#100 - 199 & #500 - 999). That should give you plenty of common variables to work with.
    The factory canned cycles are most definately using locals and #100 sets. But you should be free to use them as well. Thats the reason why the control will dump them after execution, at reset, or end of program. You're not going to affect the machines canned cycles just because you're using the same local sets.... At least I've never run into it in decades of programming.....
    The thing to watch for are the commons (#500, etc). Many machines with special options may use some of these variables for opional components like tool probes (Tool Length Measure Units), secondary spindle positions, Pallet ID, Machine ID, etc, etc , just to name a few things. Change one of those on a machine that uses it and you may be in for a surprise.
    Feb 2007
    67
    #1=1<EOB>
    the control accepts the input but when cycle start is pressed, the error "Invalid break word point" (paraphrased) is shown. I assume I don't have Macro B installed?
    Thanks for all the replies BTW...
    24223
    Check bits 913 #7 Macro B 917 #4 Var 149-199 & 531-999
    Correction: that is for the 0 the macro B for the 10 is 9111 bit #0
    Albert E.
    Jan 2007
    91
    check your inbox.
    I think I sent you a private message the other day concerning parameters
    -Jim
  1. Manual plasma installed on a cnc problem!
    By baranac in forum Community Club House
    Last Post: 08-10-2006, 07:08 AM
  2. what is a macro?
    By ljoe1969 in forum Autodesk
    Last Post: 07-12-2006, 02:12 PM
  3. EZTrak with factory installed 3rd axis.
    By Gncc50 in forum Bridgeport / Hardinge Mills
    Last Post: 04-08-2006, 07:13 PM
  4. Help gettig pure dos installed
    By Hack in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-03-2005, 03:26 AM
  5. Caps Installed Wrong Please HELP
    By jockey in forum CNC Machine Related Electronics
    Last Post: 02-27-2005, 05:48 PM
