586,051 active members*
3,807 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > Newbie - Build my own CNC of 1500x500mm // Max. Budget 6.000 euros
    Hi all,
    I am a completely newbie in this area of CNC’s. I would like to hear your comments about building my own CNC Router.
    I need a milling area of 1500x500mm. Z axis could be around 110 - 150mm... Repeatability precision not less than 0,02mm.
    Do you think this is “doable” within a budget of 5.000 / 6.000 euros? If so, do you know any Build Thread like this that shows me how to do it? I don’t know where to buy the components.
    Many thanks in advance.
    Best regards,
    Gonzalo
    Apr 2004
    5737
    Re: Newbie - Build my own CNC of 1500x500mm // Max. Budget 6.000 euros
    That budget sounds feasible for a router, but the repeatability doesn't. Decrease your tolerances by a factor of 10 or increase the budget similarly, and you should be able to achieve it.
    Andrew Werby
    Website
    There are already commercial ones for 12.000 / 15.000 € with tolerances of 0.01mm like the ones from CNC Machine Manufacturer - CNC Routers and Engraving Machines I am asking for 0.02mm, but surely when building it homemade, I guess getting that Precision is not so easy.
    Can somebody forward to me any similar Build Thread in which indicates where to get all the components and which ones are of the best quality?
    Thanks!
    Finally I decided that it was not worth to make the machine by myself... I have bought a CNC router of 140cm (X axis) from CNC-STEP.... price was over my budget, I spent 9.500 €, but the quality and Accuracy that I am getting is expected to be really good.
    https://www.cnc-step.com/cnc-router-...ws-1400x800mm/
  1. newbie just built a very low budget CNC router looking for a bit of advice
    By alanesq in forum DIY CNC Router Table Machines
    Last Post: 03-25-2018, 07:34 AM
  2. $4K Budget - Buy or Build?
    By TheRocket in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-08-2016, 10:09 PM
  3. First CNC Build, very low budget
    By vaxo93 in forum DIY CNC Router Table Machines
    Last Post: 05-09-2015, 02:25 AM
  4. Newbie on a budget wants to get a small CNC lathe
    By dvirb in forum MetalWork Discussion
    Last Post: 10-21-2014, 07:00 PM
  5. Newbie with the CNC bug but not the budget
    By kitcabsource in forum Uncategorised WoodWorking Machines
    Last Post: 11-07-2013, 02:34 PM
