586,043 active members*
3,643 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > stainless steel ID shrink in heat treat? 420
    Jan 2020
    19
    I have a part that has a diameter of 4 inches, 1.5 inches long and with an ID that's supposed to be 2.626 inches. the current ID is 5 grand over. I'm just curious if heat treat will be able to shrink the ID at least 3 grand. the steel is 420 stainless. I could just scrap it but would be a waste of 328 dollars if it can be saved.
    Mar 2008
    683
    Re: stainless steel ID shrink in heat treat? 420
    Not likely. But if it doesn't cost much to treat have them run it.
  1. Tool steel heat treat RFQ. Colorado, boulder area
    By swisswilson in forum North America RFQ's
    Last Post: 06-08-2016, 03:18 PM
  2. Passivating Heat Treated Stainless Steel
    By msomerville in forum MetalWork Discussion
    Last Post: 01-20-2015, 05:17 PM
  3. a2 steel heat treat - oversize tap 3/8-16 ?
    By PETE1968 in forum MetalWork Discussion
    Last Post: 04-10-2013, 08:53 PM
  4. Heat treatment of stainless steel.
    By zoeper in forum MetalWork Discussion
    Last Post: 12-18-2008, 03:19 PM
  5. ACME - 1018 steel or heat treat 4140 alloy
    By CnC_BoY in forum Linear and Rotary Motion
    Last Post: 03-21-2006, 11:41 PM
