586,069 active members*
3,721 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > any one live in the brevard florida area? need help with Mach4 to start!
Results 1 to 6 of 6
    Mar 2020
    4
    easy 3 axis machine im building and trying to set up mach4 software/settings and a DB25-1205 break out board with a PMDX-411 usb adapter. i've had techsupport log into my computer and set everything up on the mach4 side of the software but i get zero movement. double checked all the wiring and looks perfect. i'm not a software guru so willing to pay some one to come over and take a look to help me get this sucker up and running. any help would be great!
    Attached Thumbnails Attached Thumbnails IMG_4199.jpg   IMG_4198.jpg   IMG_4130.jpg
    1227
    Re: any one live in the brevard florida area? need help with Mach4 to start!
    I don't know the first thing about Mach4 and I don't live anywhere near Florida.I have however built a machine that uses a similar BOB and it had one of a similar type of black controller box per axis.I am attempting to attach a witring schematic for a similar system to illustrate the point.The part numbers may be different,but I would expect the principles to hold.
    Mar 2020
    4
    thank you and that looks similar to the one i have already. ive double checked the wiring and all looks inline fine. just sounds like setting within mach4 which is confusing for me.
    Attached Files Attached Files
    1227
    So where are the other two controller boxes sited?I suspect you have the 4 (or more) cables from the steppers connected in such a way that the drive circuit is incomplete.
    Mar 2020
    4
    this look correct? not trying to make a complicated machine. just to cut EVA foam.
    1227
    That looks like a controller with ample gaps around each component.The areas I would focus on are the pins on the plug connecting to the BOB to be sure the correct voltage,which I would expect to be 5V, is arriving at the correct place and then the steppers to make sure that each pair of connections are receiving the voltage that the controls are set for.
  1. NE Florida, Jacksonville Area
    By T_om in forum USA Club House
    Last Post: 08-13-2019, 06:58 PM
  2. Anyone in the central Florida area?
    By sen2two in forum Milltronics
    Last Post: 08-09-2018, 05:41 PM
  3. Ocala Florida Area
    By ljh34481 in forum Tormach Personal CNC Mill
    Last Post: 06-05-2013, 07:19 PM
  4. Central Florida Orlando Area?? $$
    By pike88 in forum Mentors & Apprentice Locator
    Last Post: 06-05-2007, 04:34 AM
  5. Anyone here from Tampa Florida area?
    By balsaman in forum Community Club House
    Last Post: 02-15-2004, 09:12 PM
