586,116 active members*
3,469 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > File Extension Question
Results 1 to 11 of 11
    May 2006
    150
    Guys, what is the file extension for a Centurion 6 (floppy drive)?
    I'm trying to write some programs via CAM software. So far, the mill doesn't recognize that a program is on the floppy. The floppy was formatted prior to using it.
    Thanks in advance.
    P.S. Please tell me any other advice that you think I'll need to get the mill to read files.
    Apr 2003
    637
    .ncc should work
    Jan 2007
    333
    There is NO file extension.... just O1234. or P1234. (for conversational progs).
    You can enable the parameter "Full DOS File Names" and it will read ANY FILE on the disk, but be careful not to try and read anything other than a gcode file in ASCII format or it can lock up the control or scramble parameter(s). In other words, don't try to read an .exe or .jpg file.
    May 2006
    150
    How do I save a file with no extension?
    I opened the .txt file in Notepad, then tried to save it with no extension. I think that it was saved as a .txt file.
    The controller didn't recognize the .ncc file either.
    Maybe I should switch to "Full DOS File Names".
    Please advise. Thank you for your help.
    Aug 2005
    1622
    Just rename it as O#### without an extention. You will get a warning about changing file types, but ignore that.
    If this is the first run posting from your cam package, verify it on the control, then run it dry without cutting tools to be sure it runs as expected.
    DC
    Jun 2007
    35
    Check you folder options on your pc. Make sure they show hidden files so you can rename them without ext.
    Feb 2007
    156
    You don't even need an o (oh) in front of the prog number. My controls are switched to use full dos file names. I use floppy's with only programs for the machines. The only tome you need an o (oh) is for calling sub programs.
    Dave
    Schneider Machine
    A force of one
    Jan 2007
    333
    You are forcing the .txt extension in notepad because you didn't change "File Type" in the flip out pane to "*.* All Files", you've left it as File Type *.txt
    These are found at the lower area of the window that pops up when you select "Save AS"
    Jul 2004
    97
    Change File Extension
    Check Your Cam Software Too See If You Can Change How It Is Saved. That's What I Did. Just Save It With The Period And No Extension. Hope This Helps.
    May 2006
    150
    Guys, thanks for your help so far.
    My mill still doesn't recognize the files on the floppy. I can change the 'Save As File Type' to all files, but it wtill writes a text file. I don't have an option for ASCII encoding.
    When I look at the program from Explorer, it is still a text document.
    Thanks for your help.
    May 2006
    150
    Woohoo! It now reads the programs on the floppy!
    I had made many changes, but had not added the period at the end of the file name.
    Thanks guys! :cheers:
  1. What is a M3P extension
    By bill south in forum Mach Wizards, Macros, & Addons
    Last Post: 12-10-2014, 08:39 AM
  2. question about file converting
    By cncmachiningzon in forum Solidworks
    Last Post: 04-14-2007, 04:51 PM
  3. post file extension
    By GRANDPA in forum Mastercam
    Last Post: 03-22-2007, 04:44 AM
  4. Extension Cord
    By dneisler in forum Welding Brazing Soldering Sealing
    Last Post: 01-14-2006, 02:29 AM
  5. Log file question...
    By murphy625 in forum CamSoft Products
    Last Post: 04-05-2005, 10:12 PM
