586,119 active members*
3,600 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > 48v AC stepper motor driver advice ma860h
Results 1 to 7 of 7
    Mar 2020
    4
    Hello,
    I have a 48v AC stepper motor and need to buy a driver to control the motor.
    I was looking ma860h driver. Someone have feedback about that driver? Any other suggestion?
    Best regards.
    Apr 2004
    5737
    Re: 48v AC stepper motor driver advice ma860h
    Every stepper I've ever seen ran on DC. Are you sure yours is AC? Are you sure it's a stepper motor?
    Andrew Werby
    Website
    Jul 2018
    6341
    Mar 2020
    4
    Quote Originally Posted by awerby View Post
    Well, not so sure.
    Motor ref: HY200 3437 0660 AK04
    I cant find all the information about the motor. I know its hybrid, have 4 leads, 2 coils and 6.6A phase current.
    I assume it was AC because with the motor have a transformer to 48V but i dont find any retifier circuit, but i can be wrong.
    Can i make any test to see if it is AC or DC ? maybe using it as generator ... ?
    Thanks for your answer.
    Jul 2018
    6341
    Hi Jacare - A stepper motor runs on pulses provided by the driver. The driver can accept AC or DC and the driver rectifies it onto the correct waveform. Peter
    Mar 2020
    4
    Hi Peter, it makes sense now. So basicly its not important if it is DC or AC because the wave will need to be retified for the pwm provided by the driver right?
    Thanks for your anwser.
    Best regards.
    Jul 2018
    6341
    Yes you got it. Check the input voltage specs for the driver in its manual. Good luck Peter
  1. New power supply question for MA860H Stepper Motor Driver
    By mike3385 in forum Stepper Motors / Drives
    Last Post: 06-21-2017, 01:19 AM
  2. Stepper Motor Driver MA860H power supply connection
    By airtruk in forum DIY CNC Router Table Machines
    Last Post: 10-24-2013, 03:06 AM
  3. Ma860h driver faults help needed
    By wavewizards in forum Servo Motors / Drives
    Last Post: 04-24-2013, 08:34 AM
  4. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
  5. STEPPER MOTOR AND DRIVER CONNECTION ADVICE
    By GASANT in forum Stepper Motors / Drives
    Last Post: 08-25-2011, 05:20 PM
