586,443 active members*
3,106 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Mills > Emco F1 Mill Z axis not moving in the negative direction
    Apr 2020
    Hi everyone
    I have an emco f1 mill and it moves in the positive direction but it won't move in the negative direction. I'm not sure if this is due to a loose wire or not. I would would appreciate any help.
    Thanks!
    Jan 2017
    9
    Re: Emco F1 Mill Z axis not moving in the negative direction
    Is your machine an F1 or F1P?
    I can only answer for the F1 school machine
    Does it not work in both CNC and hand mode?
    If only in hand mode it can be the -Z button or the solder joints or the leads of the button.
    Check the 2 solder points with an Ohmmeter on the CPU board, when pressing the button you must measure 0 Ohm.
    Of course unplugged from the mains!
    Dieter
