586,121 active members*
3,643 visitors online*
    Dec 2005
    9
    newb question-turning arc on or off
    I have a new home built cnc setup I would like to use as a plasma cutter. I'm wondering how I turn the torch on or off by computer control. I don't really see the need for a THC. I can control the height by moving the z axis but how does the machine know when to start moving the machine again after the torch starts, after a stop to skip over a section without cutting it. How do I stop the torch so I can skip over a section without cutting it? I have a Hypertherm Powermax 900 plasma torch. Wondering about wiring it up for computer control too. Its set up for hand use right now.
    Sep 2006
    118
    Re: newb question-turning arc on or off
    Depending your controller and CAM software you need a post processor for plasma CNC that will write the torch on/off into the Post file. If you're using GCode you can also do this manually if you have a basic knowledge of writing GCode. For control of the arc on/off for the HT900 ask Hypertherm, I'm not familiar with that model, the newer HT's have remote torch control thru a CPC AMP connector.
  1. newb question here
    By aaronajb in forum DIY CNC Router Table Machines
    Last Post: 10-25-2018, 09:59 PM
  2. Question for a Newb!
    By Bcb871810 in forum Uncategorised CAM Discussion
    Last Post: 07-09-2017, 12:04 AM
  3. NOT A NEWB BUT THIS IS A NEWB QUESTION
    By BOATDUDEGUY in forum Mastercam
    Last Post: 05-15-2012, 09:38 PM
  4. Newb Question
    By AndrewJP in forum Uncategorised MetalWorking Machines
    Last Post: 09-15-2010, 08:16 AM
  5. newb has a question
    By Rookie in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-15-2007, 01:21 AM
