586,119 active members*
3,490 visitors online*
    Dual focus lens
    I am attempting to set up a dual focus lens for laser cutting. I have a 5" fl final lens and a 1"fl first lens. The problem I have is when I install the 1"fl lens between the laser beam and the 5"fl final lens, I lose almost all the output power. The dual lens should reduce spot size and therefore concentrate cutting power. I have to be missing something.
    Dec 2006
    124
    Re: Dual focus lens
    The off-the-shelf focus lenses are designed to take in a collimated laser beam (that means the laser beam is coming straight into the lens). However, in your setup you angle the incoming side laser beam because you use an upstream focus lens.
    There are a lot of geometric optic software programs that will show what is happening, and a lot of youtube tutorials on the subject, and you could simply sketch it out by hand after watching some informative youtube vidoes then see what is going on, then change your design or lens configuration. You can also contact suppliers of lenses for their assistance.
    Nov 2010
    787
    Re: Dual focus lens
    Quote Originally Posted by robertlroberts View Post
    Dual focus lens do not means dual lens (flame2)
    CNC lasers, constructions, service
  1. Focus lens
    By Miron.Costin in forum Laser Hardware
    Last Post: 04-20-2019, 01:53 AM
  2. What focus lens to use
    By Miron.Costin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-03-2018, 09:32 AM
  3. focus lens
    By lasertube in forum For Sale Only
    Last Post: 08-25-2014, 03:48 PM
  4. DUAL FOCUS LENS (bifocal lens)
    By bibi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-12-2013, 08:56 AM
  5. Focus lens
    By jtj30 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-03-2006, 04:10 PM
