586,071 active members*
3,900 visitors online*
IndustryArena Forum > Mechanical Engineering > T-Slot CNC building > Minitec T Slot Extrusion in Australia
    Jan 2007
    626
    Anybody know where I can buy Minitec Extrusions and fittings
    in Australia, preferably WA?
    Looking for 45 Series.
    Aug 2015
    21
    Re: Minitec T Slot Extrusion in Australia
    Hi mate,
    I don't know about Minitec, but you can get ITEM extrusion from Modular Components, which is what I use. It is really good quality, but it may not be the cheapest option. There's some other suppliers selling cheaper extrusion, but I can't comment on that. Hopefully this helps.
    Jan 2007
    626
    Thanks Stepping.
    Ive seen the Item stuff. Very good , but not the 45 series I was after.
    May have to look overseas me thinks.
    Sent from my SM-G920I using Tapatalk
    Jan 2021
    Quote Originally Posted by Sterob View Post
    Thanks Stepping.
    this really helped me, thanks for sharing.
    Jan 2021
    Ive seen the Item stuff. Very good from https://expertwatchman.com/, but not the 45 series I was after.
  1. Aluminum T-Slot Build Using Misumi Extrusion
    By Bear5k in forum T-Slot CNC building
    Last Post: 10-07-2016, 11:17 PM
  2. Looking for thoughts on a plastic t-slot extrusion system
    By MongoToys in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 06-01-2016, 12:19 AM
  3. 626 Ball bearings & 5mm extrusion slot
    By Dept-74 in forum Linear and Rotary Motion
    Last Post: 04-30-2015, 08:23 PM
  4. Anyone used Polythene pad slides for T slot extrusion
    By cweeks in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-10-2009, 12:29 PM
  5. T-slot Router Bed Extrusion
    By gotswrv in forum Want To Buy...Need help!
    Last Post: 07-11-2008, 02:16 AM
