I want to bolt my 30mm spacing linear rails to the inside of an square(ish) frame constructed of 3060 extruded aluminum from 80/20. The linear rails are 1300mm sbr16 and it appears their bolt holes line up with the 3060 drawings.
For background, I've fabbed up the whole cnc using mild steel 1"x2" tubing and the pillow bearings are binding in the Y axis. The base frame is as square as my square can indicate, and all sides are as completely parallel that I can measure.
The only problem I can see is that I had to weld the frame together on my garage floor (not the flattest surface), and perhaps there is an issue I don't know to look for.
If linear rails + extruded aluminum will work, then I don't mind starting with factory cut parts as I don't have a solid surface to work from yet.
