586,106 active members*
3,027 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > VFD Wiring to generic BoB
Results 1 to 12 of 12
    Apr 2020
    6
    hey guys .. you guys are alot of help... im new here and im putting together my cnc build...
    im tryin to wore my HY VFD to my break out board but i dont have the NVUM i have a the one that comes in a kit ill post a pic of it... can someone help me with wireing from VFD to this BoB i just need to be able to turn the spindle on and adjust speed...thanks.
    24221
    Re: VFD Wiring to generic BoB
    What is that web site and model printed on the board,?
    Al.
    Albert E.
    Apr 2020
    6
    its the bitsensor.com
    BSMCE04U-PP
    Apr 2020
    6
    i tried to look it up.. i know from my VFD i have to run from DCM , FOR , ACM , and V1 but idk where to wire them to my BoB
    at least i think thats what i need
    24221
    There is a few details on hook up out there if you Google, it does not seem to have a good reputation according to Mach sites etc.
    Also a mention of the Manuf. not supporting it any more and seems to have skipped!
    What is the 16pin IC device # next to the outputs?
    Al..
    Albert E.
    Apr 2020
    6
    not sure what that 16pin is...
    24221
    BTW, there are series of Utube videos that show the installation, set-up and usage of that BOB, the videos are by BuildyourCNC.
    Al.
    Albert E.
    Apr 2020
    6
    yes i saw those videos... but they dont show the wiring for the VFD. they show everything but that...
    24221
    One showed the relay hook-up for FWD REV?
    There is also a wiring diagram out there that shows the input to the VFD relay in and AV1-AV2 for the analog.
    Al.
    Albert E.
    Apr 2020
    6
    still no luck... im about to give up on it...
    15362
    Quote Originally Posted by Daniko88 View Post
    This board does not have a PWM to Analog 0-10v output so it can not control the spindle speed, you can use an output to a PWM to Analog 0-10v board a Relay can be on this same Board as well for the On / Off control
    A board like this or one with a Relay as well will do the job
    Mactec54
    Nov 2011
    Hi everyone.
    BSMCE04U module.schematic.
    https://www.cnczone.com/forums/contr...cnc-posts.html
    RV mineirin
  1. G code for generic ellipse
    By Jul947ian in forum Uncategorised CAM Discussion
    Last Post: 01-03-2016, 06:55 PM
  2. Generic Swiss post
    By zumone in forum GibbsCAM
    Last Post: 05-16-2015, 02:41 AM
  3. Replies: 33
    Last Post: 02-24-2010, 10:39 PM
  4. Generic name/term needed
    By MrWild in forum CNC Machine Related Electronics
    Last Post: 12-22-2007, 08:53 PM
  5. 1/4 - 20 generic vs acme?
    By 9xnet in forum DIY CNC Router Table Machines
    Last Post: 05-06-2007, 05:55 PM
