586,103 active members*
3,224 visitors online*
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Nov 2013
    4375
    Re: CNC Router - New PC Parallel Port Pickle!
    I bought a dual core Atom based Mini-ITX single board PC using on chip graphics, it had one built in parallel port.
    It is a VERY low power PC, below the minimum recommendations for Mach, and by quite a margin.
    I loaded 32 bit Windows7 Embedded and proceeded to run Mach3's parallel port seamlessly for a year before I added
    a second parallel port in the form of a PCI card and ran that for another year.
    The only time I ever had any issues was when I made the mistake of changing screens or causing a tool path redraw
    or similar.
    Then, about five years ago I bought an Ethernet SmoothStepper….and it puts parallel ports into the shade, way smoother and VERY
    VERY much less prone to hickups/stalls etc. Best $180 improvement I've ever made to my machine.
    I have also switched to Mach4 which is a quantum leap from Mach3.
    The bottom line is that 32bit Windows7 will run a parallel port, but do yourself a favour and get an Ethernet SmoothStepper or a UC300 or a 57CNC
    and all those quirky stalls etc are history.
    Craig
  2. #22
    Jun 2010
    4256
    I am running a 'several-years-old' dual processor Dell with W7 at present. Is it 32 bit or 64 bit? I am not sure. It drives an ESS. I monitor the CPU load and memory load via Task Manager all the time.
    Mach3 does not cause much more than a small blip in CPU load.
    I can easily run Autosketch, a very fine 2D drafting package, at the same time without any inconvenience.
    However, I can crash Mach3 by trying to zoom and rotate the on-screen display of the cutter path while the machine is busy. Be warned!
    These days I do not try to alter the display while running.
    Cheers
    Roger
  3. #23
    Dec 2016
    48
    I'm running a Win7 32 bit Acer with Warp9 ESS and so far the only problem has been it stopped in the middle of a 3D cut. Seems the idiot driving it forgot to turn off the computer shut down after X amount of time! It can run Acad and Aspire products but I choose to use my Win10 for the programming as I still watch Mach3 working. Habit I got into with a crappy Chinese controller. Time is no longer money being retired.
Page 2 of 2 12
  1. FWIW: Controller/brain transplant for 3-axis Chinese CNC router to use parallel port
    By cnczane in forum Uncategorised WoodWorking Machines
    Last Post: 02-07-2017, 02:58 PM
  2. Need plug to connect router to parallel port
    By cenpen in forum Controller Cards
    Last Post: 10-15-2016, 11:57 AM
  3. parallel port dead with pc-suggestions for purchasing usb/ethernet to parallel port?
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 08-19-2015, 11:32 AM
  4. no new computers have parallel?? experience on adding parallel port yourself?
    By teglberg in forum Mach Software (ArtSoft software)
    Last Post: 11-26-2014, 07:18 PM
  5. parallel port or parallel universe
    By bruno34 in forum Taig Mills / Lathes
    Last Post: 04-15-2009, 04:58 PM
