586,113 active members*
3,209 visitors online*
    R Parameters for T32 on QT15N
    Hi Mazak guys,
    I have a Quick Turn 15N with a T32B control. I'm having problems using extending/retracting the quill/tail sleeve using M codes. I get the illegal M code error. I believe this has to do with the R machine parameters (page 11), specifically R59. However, no matter how I change it, I'm getting the same error. If someone with the same machine (with working quill/tail sleeve extension/retraction using M codes) could take pictures of the parameter page (machine parameter page 11, but preferably all the pages if it's not too much of a bother) so I could compare them with my own machine, that would be great.
    All the best,
    Raz
    May 2019
    15
    Re: R Parameters for T32 on QT15N
    Viber +38640576587
    Gesendet von meinem SM-N950F mit Tapatalk
  1. Replies: 3
    Last Post: 10-22-2020, 09:20 PM
  2. Mazak QT15N / Mazatrol T32-2 39over amper alarm
    By shadediggity in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-11-2014, 08:02 PM
  3. mazak qt15n alarm 250
    By bolbogetz in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-19-2010, 03:27 PM
  4. Adding a steady rest to T32-2 qt15N
    By carbidecraters in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-01-2010, 06:15 PM
  5. PARAMETERS
    By bigbaz in forum Haas Mills
    Last Post: 09-22-2009, 05:32 AM
