586,111 active members*
3,522 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Toolgrinding / Toolgrinding Machines > Punch grinding with 5C spin index on surface grinder
    Oct 2004
    39
    Hey everyone,
    I was wondering if anyone had insight into this process. I need to grind some punch blanks with my 5c spin indexer on my surface grinder. My question is this: do I set the wheel directly on the center of the punch or slightly to one side? Thanks to anyone who can help.
    Regards,
    Phil
    Jan 2004
    3154
    Direct center or a wee bit behind.
    www.integratedmechanical.ca
    Mar 2011
    Set the wheel directly on the center of the punch never to one side. And I advice to use a DEDTROU for this type of jobs.
    Dec 2004
    120
    Depending upon what you intend to do, a 5C spin fixture isn't considered accurate enough for grinding the OD of a punch. Most die work that I did was held to .0005 TIR or less and that was an accepted standard. Length of the punch will also affect the OD, rendering a taper as most 5C spin fixtures simply aren't made to do work of this nature with any accuracy. If it's a small/short detail on the end of the punch then disregard what I'm saying here. A 5C spin fixture is fine for milling or looser tolerance grinding but you should be aware of why it's not used for precision work. There's a direct link between cost of the tooling and the capability of it, you get what you pay for.
    May 2004
    4519
    Quote Originally Posted by roninB4 View Post
    +1
  1. Why is surface grinding so accurate...
    By WilliamD in forum Uncategorised MetalWorking Machines
    Last Post: 07-22-2007, 12:14 PM
  2. Surface Grinder
    By gbowne1 in forum Uncategorised MetalWorking Machines
    Last Post: 02-28-2007, 06:28 AM
  3. Surface Grinding Aluminum?
    By kumaichi in forum MetalWork Discussion
    Last Post: 10-31-2006, 01:24 PM
  4. Surface Grinder
    By itsme in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2006, 06:28 AM
  5. disassembling 5C spin Index
    By Runner4404spd in forum MetalWork Discussion
    Last Post: 06-14-2006, 04:56 AM
