586,060 active members*
4,209 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Older industrial VFD (Allen-Bradley) to CNC controller?
Results 1 to 9 of 9
    Mar 2020
    179
    In the planning phase for a CNC build. A friend has a line on older used industrial VFD's for a really good price (photo attached). Is something like this compatible with modern CNC controllers? From what I've heard with the Huanyang VFD's it's best to avoid them if you can afford it. Sounds like these are burly and last forever. The heat sink alone is massive. This one in particular is somewhere around 3.3 kW, which is bigger than I need but still cheaper than a cheap new one anyway.
    Secondarily, how hard is wiring this kind of thing up? I've done some basic circuit design of PID controllers, relays, etc, but am by no means an expert. The guy who has a stash of these is also willing to do the install, though I assume I'd be on my own for the actual CNC controller interface.
    Cheers,
    Brian
    Attached Thumbnails Attached Thumbnails IMG_20200408_093715.jpg   IMG_20200408_093808.jpg   IMG_20200408_093813.jpg
    24221
    Re: Older industrial VFD (Allen-Bradley) to CNC controller?
    They are well made VFD's Way better than Huanyang.
    Just ensure it will take 1phase, you should be able to get the manual from the AB site.
    What is the Model No? Looks like an older version, the only issue is the capacitor bank if it has been in disuse for some time.
    Al.
    Albert E.
    Mar 2020
    179
    Thanks. I'm not sure on this model number, and it sounds like this guy has a stash he purchased of surplus VFD's so the model may not necessarily be the same for whatever is available now as this particular one.
    Nov 2012
    1267
    Those older VFDs are not much different from modern ones - just bigger, heavier, uglier and (originally) much more expensive. Should work just fine for a CNC machine.
    15362
    Quote Originally Posted by catahoula View Post
    Cheers,
    Brian
    It will depend what you want to run with it as it may not be suitable if you want to run a high speed spindle normally these old drive are fine for a regular 3Ph Ac motor 50/60 Hz
    Being used for reliability they will want the Caps changed
    Mactec54
    24221
    Quote Originally Posted by CitizenOfDreams View Post
    Yeah, some of the older versions were a little over-engineered.
    I have some Telemecanique that were specifically built for 1ph and they are still working like a charm.
    And yes $$$$.
    Al.
    Albert E.
    Mar 2020
    179
    Can you elaborate on the issues with high speed spindles? Based on the materials and tools I'll be using this will be a quite rigid router with a high speed spindle.
    24221
    What is the model #?
    You can most likely find the manual on the AB Rockwell site still.
    If you have one, check to see if the VFD can be set to 400Hz.
    Al
    Albert E.
    15362
    The spindles require 300Hz and 400Hz depending on what spindle you get your VFD Drive most likely will not support 400Hz
    Mactec54
  1. Allen Bradley Controller used with CAD software
    By pwarningDW in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-29-2012, 02:48 PM
  2. Allen Bradley Banit 1 controller problems PLEASE HELP!!!
    By notchtopper in forum Controller & Computer Solutions
    Last Post: 10-16-2011, 02:55 AM
  3. Allen Bradley Series 8200 Controller
    By ImanCarrot in forum Controller & Computer Solutions
    Last Post: 02-04-2010, 11:35 AM
  4. Kitamura Mycenter-1 with Allen Bradley 9/240 controller
    By DaveWright in forum Uncategorised MetalWorking Machines
    Last Post: 12-01-2009, 03:42 AM
  5. Northwood W/Allen Bradley 8400 Controller
    By SteAlger in forum Commercial CNC Wood Routers
    Last Post: 11-16-2009, 07:54 PM
