586,096 active members*
3,112 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > Alarm 8140 - Maschine (ACIF) not responding EMCO PC MILL 155
    Hello everybody! I hope that you are very good in your confinemen.
    I have a PC MILL 155 and the display to show this message: Alarm 8140 - Maschine (ACIF) not responding.
    I have check the current in main drive control is the 48v, I have the electric wiring, i think that it's OK. A detail, the led axis drive it's off in the 3 axis.
    Someone had the same problem? Could you help me about which the solution?
    Thank you very much!
    From Barcelona.
    Mar 2014
    44
    Re: Alarm 8140 - Maschine (ACIF) not responding EMCO PC MILL 155
    Im pretty sure that your communication cable is not working. So check the 4 wire cable between your control and the machine
    Good morning and good new year!
    After long time...:wave:....
    Arjand thanks for you answer and time.
    These are the steps taken today..
    1. Check the current in main drive control 24v --> It's OK
    2. Check the 4 wire cable between your control and the machine --> continuity between wire --> It's OK.
    3. Visual check PC COM BOARD ref. Y4A083000 --> It's OK
    Anyone have other idea? thanks for you help me.
  1. Need Help RS 485 alarm on Emco PC120
    By rr167 in forum EMCO Lathe
    Last Post: 01-05-2016, 07:39 PM
  2. Emco F1P-CNC error alarm please help
    By OLDTOAD in forum EMCO Mills
    Last Post: 02-14-2013, 02:32 PM
  3. Emco 340 Alarm
    By WIRE CUTTER in forum EMCO Lathe
    Last Post: 04-24-2011, 05:12 PM
