586,035 active members*
3,828 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > Spindle conversion help needed
Results 1 to 5 of 5
    Hi Everyone, I'm with a student group and we are building our own cnc milling machine to gain experience in engineering and we are having some troubles converting our spindle. We have received a 15k rpm 40 taper belt driven spindle that we believe to be out of a haas mini mill and we are trying to convert it to direct drive so we can use our machine for rigid tapping. The tricky bit is that since the drawbar is in the center (shown in first pic), and the drive is on the outside of that, that means that we have to have some interesting intermediary system between the motor (intended to be a high speed servo) and the spindle to allow for automatic tool changes and minimal backlash to allow for rigid tapping. My question is, does anyone know how industry direct drive spindles in machines capable of rigid tapping accomplish this? In a different haas machine I see a pin and slot method (shown in pictures) that would work but I am worried about the clearance between the pin and slot being too large too accommodate rigid tapping. I have thought of using a tapered slot and a trapezoidal cross section to reduce backlash, but that's fully custom and hard to manufacture. Do y'all have any suggestions or industry knowledge that might help?
    15362
    Re: Spindle conversion help needed
    Quote Originally Posted by Daedalus308 View Post
    You would use the belt drive and an encoder on the spindle for rigid tapping there is not much to it
    Mactec54
    somehow that was actually something that we hadn't considered and i feel dumb for that. although we also want to do direct drive for a few other reasons (we will have a funky machine layout) so I think we'll stick with it
    Mar 2017
    411
    A timing belt with 1:1 ratio is basically direct drive.
    The benefit is a lot less complexity.
    May 2016
    316
    Direct drive spindles that I've seen - and there may be other layouts - are either:
    1. Integrated spindle motors, or
    2. Hollow-shaft motors.
    Integrated means the machine builder buys a rotor & stator set from a motor mfgr with a specified bore & mounting arrangement. The rotor is slid over the spindle OD and fixed in place with the spindle bearings mounted outboard of the rotor. The spindle becomes the motor 'shaft' if you will, and any through-spindle features (drawbar, coolant/air/bearing lube/etc.) is passed though the spindle as usual.
    The SKF Bearings web site has some excellent spindle arrangements - demonstrating their bearings, of course - but they show diagrams of integrated motor spindles as well.
  1. Help Needed.... Axis Conversion and sizing.
    By giannifp in forum Benchtop Machines
    Last Post: 04-24-2019, 05:24 PM
  2. X2 Mini Mill Conversion Kit Needed
    By twwilson1 in forum Benchtop Machines
    Last Post: 06-16-2016, 03:07 PM
  3. File conversion needed MC9 to dwg/dxf
    By babinebruce in forum Mastercam
    Last Post: 07-24-2009, 09:19 PM
  4. Need Help! File Conversion Needed
    By thebristolbloke in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-13-2009, 04:20 PM
  5. Speed / Feed Conversion Help Needed
    By LarryA in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-02-2008, 03:47 AM
