586,114 active members*
3,337 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Help needed with Esprit 4 axis Wrap contouring
    Apr 2020
    Hello Guys,
    I am using Esprit 2019. I am trying to machine a circular groove on this part using the 4 axis on an Okuma mill. I created a chain on the circumference of the part groove. Then I tried using Wrap contouring on Esprit but when i try to create the tool path I get and error message that says "Wrap operation requires wrap axes. Axes is not specified in Machine Setup". I have no idea how to set up the wrap axes. Any help will be really appreciated. Here are a couple of pics of what I am trying to do. Thanks
    Attached Thumbnails Attached Thumbnails Ring Wrap Contouring (2).jpg   Ring Wrap Contouring 2 (2).jpg
    Apr 2017
    7
    Re: Help needed with Esprit 4 axis Wrap contouring
    In your machine setup you need to specify that you have a 4th axis. This is from our setup file for a Doosan DNM 6700 with a 4th.
