586,115 active members*
3,476 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach Slant Lathe > Anybody know the shaft diameter for the stepper motor
    May 2008
    667
    I would like to try some other brand of stepper motor and want to know the shaft diameter for both stepper motors,
    Thanks a lot, Jeff
    Re: Anybody know the shaft diameter for the stepper motor
    I bet I could find a picture of the part number on the motor while I had things apart. I'll check tomorrow.
    Curious why you want to change them out though.
    May 2008
    667
    Quote Originally Posted by number40Fan View Post
    I bought 2 of these 3 phase servo stepper driver and corresponding 1130 oz stepper with encoder and brake.
    Drive work with 220v
    Shaft diameter is 14mm
    Just wanted to know in advance if shaft dia were the same, will try to replace original motors in a couple of weeks if I have enough free time.
    Thanks for the reply
  1. 6040 stepper motor shaft and leadscrew diameter
    By rthorntn in forum Chinese Machines
    Last Post: 02-27-2018, 07:37 PM
  2. Preferred stepper motor shaft diameter
    By ahacking in forum Stepper Motors / Drives
    Last Post: 05-27-2016, 03:00 PM
  3. X3 Motor Shaft Diameter
    By pzzamakr1980 in forum Benchtop Machines
    Last Post: 12-26-2007, 10:55 PM
  4. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum DIY CNC Router Table Machines
    Last Post: 12-24-2007, 09:51 PM
  5. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum Uncategorised MetalWorking Machines
    Last Post: 12-15-2007, 04:25 AM
