586,069 active members*
3,554 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Just put 3018 together grbl not comunicating with it
Results 1 to 2 of 2
    Just put a 3018 together, it has a Woodpecker CNC GRBL 0.9 board.
    I have installed driver and set com port.
    I loaded grbl 0.8.4 as this is the software that came with the machine.
    I used settings tab and set com port and the software seems to be
    connected with the board.
    The screen says the following:
    [G0 G54 G17 G21 G90 M0 M5 M9 T0 F0.0 S31.5]
    However....
    Any commands like $ or $$, nothing happens
    I can jog x and y axis only in single steps only
    if I choose 10 steps the machine will stop moving
    at all and I have to close grbl and restart
    I cannot jog the z axis at all, when I try it
    again the machine and software locks up
    and I have to shutdown and restart.
    I can turn on and off the spindle until the
    software locks up because of the above.
    Nothing else seems to work and I cannot get
    any results from entering anything into command
    line.
    Is my board defective or am I missing something.
    Perhaps I have completely overlooked a setting.
    Any help would be greatly appreciated.
    Regards
    Charles
    May 2020
    3
    Re: Just put 3018 together grbl not comunicating with it
    I am new to all this. I purchased a 3018 cnc from Banggood and it did not come with software. I am looking for GRBL 0.8 which is suppose to be on Banggood's site. But I can't find it. May I ask where did you get yours from? I don't know if I can help with your problem but if you go to Banggood's site and search for a cnc 3018, scroll down and there are three videos. The first one is an assembly one but the second part of the video shows how to activate the software. May that will help.
  1. Replies: 15
    Last Post: 01-28-2021, 04:15 AM
  2. Sainsmart 3018 Pro using Grbl
    By portanav in forum CamSoft Products
    Last Post: 07-30-2019, 04:10 PM
  3. 3018 PRO CNC - Grbl connection problem
    By cybermerlo in forum Chinese Machines
    Last Post: 07-05-2019, 04:55 PM
  4. Woodpecker GRBL 3018 UGS Errors
    By Stephen_A in forum Chinese Machines
    Last Post: 03-17-2019, 12:30 AM
  5. NOOB NEEDS HELP HAVE A CNC 3018 WITH A "WOODPECKER CNC GRBL 0.9 BOARD) NEED TO UP RPM
    By bruce1129 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-11-2018, 04:09 AM
