586,113 active members*
3,235 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > Bridgeport knee mill, linear rails worth it?
Results 1 to 7 of 7
    Jan 2011
    10
    I have an import "Bridgeport" that's a little worn out, I would like to convert it to CNC with ball screws and instead of working with sloppy dovetails I was thinking of mounting a pair of some linear rails to the bottom of the bed and 4 linear bearings (2 each rail) for the X axis and the same for the Y axis. Am I crazy for trying to do it? Is the machine rigid enough for it and worth it? I don't want to sink all the money and work into it to find out it works as a sub-par CNC. I was to make some aluminum car parts with the setup, like brackets and mounts with it so tolerances don't need to be too crazy but I would still like some nice surface finishes and repeatedly results. Any input and advice would be really appreciated, thanks!
    Dec 2013
    5717
    Re: Bridgeport knee mill, linear rails worth it?
    Never heard of it being done before, but I can't think of a reason that it won't work. My Haas has linear rails and seems to work fine.
    Be sure to post your build thread with lots of pictures.
    Jim Dawson
    Sandy, Oregon, USA
    Jul 2018
    6341
    Hi Lambo - I think there's a dovetail to rail conversion somewhere in here try a search - Peter
    No reason for it not to work but have a very good look at it to make sure your rails do have places to land and cars do too etc. May have to machine lands for rails...
    15362
    Quote Originally Posted by 22lambo View Post
    If it is that worn, then it would cost more to redo the ways than to do the linear rail build make sure you get preloaded linear rail bearings if you do this
    I have done many of them there was one posted here on the Zone somewhere, but was not one that I had done, I mostly did the Y axis the last one I did I made a new saddle as well which kept everything at almost standard height
    When I said I have done many of them I have not done a clone only the Bridgeport Boss machines which have a heaver and wider Knee than a standard Bridgeport mill
    I also add an extra 2" travel on the Y =14"axis when I have added the linear rails
    I'm building one now that will have a added horizontal spindle as well as the normal vertical spindle, but with 16" of Z axis travel, with a total of 24" with the Knee
    Mactec54
    Apr 2014
    345
    I have an Excello with round linear rails that was done sometime in the 80’s it’s ok but the round rails are not the greatest.
    Aug 2009
    1573
    ...the price of CNC machines these days and lots of them for sale....you might be better off buying a real CNC machine.
    Apr 2014
    345
    Quote Originally Posted by machinehop5 View Post
    You could buy a real working vmc for the price of the rails and screws. Then sell the Bridgeport for the price of the vmc
  1. 6 ATC for BridgePort Knee Mill R8 Spindle
    By JHCHOPPERS in forum Bridgeport / Hardinge Mills
    Last Post: 04-30-2023, 11:09 PM
  2. hz vs rpm on bridgeport knee mill
    By billsnogo in forum Spindles / VFD
    Last Post: 07-29-2015, 12:49 AM
  3. How much is a new Bridgeport knee mill?
    By squale in forum Bridgeport / Hardinge Mills
    Last Post: 02-26-2011, 08:14 AM
  4. How much are linear rails worth?
    By breathe in forum Open Source CNC Machine Designs
    Last Post: 08-29-2010, 05:06 PM
  5. enco knee mill rebuild - worth it?
    By Asymetric in forum Uncategorised MetalWorking Machines
    Last Post: 02-02-2010, 06:31 PM
