586,632 active members*
2,885 visitors online*
    49
    canned cycles on 16t?
    Hi all I have a question about a 16t controller that I use , when the capII was installed in the machine to use the F.A.P.T. and years later I went to use canned cycles for drilling the controller would not acknowledge the drilling cycle , is this a parameter problem or not? any help I would be grateful thanks.
    May 2006
    265
    Ive got 18iT with Fapt2 and I can still use all canned cycles.
    Nov 2003
    98
    Hope this helps.
    Parameter 9929 Bit3=1 "CANNED CYCLES FOR DRILLING"
    Parameter 9944 Bit7=1 "TYPE II CANNED CYCLES"
    Bob
    49
    Thanks I'll check the parameter Monday morning.
  1. canned lathe cycles
    By PETE1968 in forum Mastercam
    Last Post: 05-27-2007, 12:44 PM
  2. Help w/ Fanuc 6T Canned Cycles!
    By andys2006 in forum G-Code Programing
    Last Post: 04-17-2007, 03:15 AM
  3. G90/G91 in canned cycles
    By alfalfa in forum CamSoft Products
    Last Post: 02-25-2007, 12:20 PM
  4. canned cycles on Haas
    By GITRDUN in forum Haas Mills
    Last Post: 09-21-2006, 01:58 PM
  5. Incremental Canned Cycles?
    By Rekd in forum Haas Mills
    Last Post: 11-15-2003, 07:23 AM
