586,069 active members*
3,471 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Bore Finish and Bore Rough in Gibbs
    Aug 2005
    50
    Hello,
    Please excuse my ignorance here, but how are the Bore Finish and Bore Rough processes different? The setting parameters are all the same so why call it two different things?
    Am I missing something here?
    Steve
    Aug 2005
    50
    Re: Bore Finish and Bore Rough in Gibbs
    I got the answer from Gibbs:
    The Rough Mill Bore generates toolpath as you would for a pocket with a roughing process, but starting from center of the bore. This type allows you to take multiple steps and set a Cut Width in the Bore tab.
    The Finish Mill Bore generates toolpath as you would with a contour process, and differs from the rough style in that it will only take a single pass (excluding spring passes).
    Apr 2017
    5
    It is confusing, I have asked them to change the terminology of the two operations before with not much of a response. I quite often use finish mill bore cycle to rough a drilled or existing hole closer to size before finishing with a boring bar, and it will confuse a non gibbs user when they see the cycle say finish bore, even though essentially I am using it for roughing....... Once you know what both do though guess it doesn't matter.
    Brandon L.
  1. Rough mill/ Finish mill bore
    By daewooevc in forum GibbsCAM
    Last Post: 01-13-2016, 07:31 PM
  2. Replies: 2
    Last Post: 10-02-2014, 02:06 PM
  3. Best Way? SL20 Rough ID with Live Emill or Bore
    By roundman in forum Haas Lathes
    Last Post: 11-28-2010, 05:20 AM
  4. Best way to finish a 10mm bore
    By creep_pea in forum MetalWork Discussion
    Last Post: 01-25-2006, 10:10 PM
