586,036 active members*
3,620 visitors online*
Thread: Rebuild
    Apr 2011
    8
    Rebuild
    It has been about 6 years since I was on this site. My machine has just been taking up space for several years. I just decided to clean the dust off. I wanted to make it bigger so I rebuilt it. I am using a RnR usb motion board. I have watched some of the videos and downloaded the xml file. I am at a loss as to how to set up the motor outputs in Mach3 (Port # and address, pins, etc.) I could use a little help from you experts. I will be using it as a router. I have installed a 1500watt spindle. I have it running off the front panel. Any help would be appreciate any help you can give.
    Aug 2009
    1573
    Re: Rebuild
    ...welcome back. Post some photos maybe of axis motor spec's and wiring would help.
    Apr 2011
    8
    Re: Rebuild
    Never mind guys, I think the xml file is fine. I am just not getting communication from Mach3,
  1. My first CNC (rebuild of an old CNC)
    By Tooms in forum DIY CNC Router Table Machines
    Last Post: 05-12-2014, 08:51 PM
  2. X2 rebuild soon to be CNC'd
    By 1HobbyMachinist in forum Benchtop Machines
    Last Post: 03-03-2012, 05:43 AM
  3. PC 690 Rebuild
    By jharvey407 in forum DIY CNC Router Table Machines
    Last Post: 10-28-2011, 01:30 AM
  4. rebuild help
    By houdini in forum I.C. Engines
    Last Post: 04-14-2008, 02:16 PM
  5. rebuild
    By corrie in forum CNC Wood Router Project Log
    Last Post: 03-20-2008, 10:29 PM
