586,103 active members*
3,121 visitors online*
Results 1 to 12 of 12
    Apr 2020
    4
    Angry G41/G42 interference
    I'm having issues while trying to run my g codes
    T8M6(Radiefres 45gr 25.0) (Tool)
    G54
    M3S8000
    G90G43H8Z1.
    G1Z-3.4F5000
    G41X0Y-25.5F1600D8
    G3J25.5
    G3J25.5
    G0G40X0Y0
    M11
    G30G0G91Z0.
    G0G90G55B0.X0Y0.
    M10
    G55
    M3S8000
    G90G43H8Z23.
    G1Z20F5000 (This is where is stops, and says G41/G42 interference)
    G41X0Y-18.75F1600D8
    G3J18.75
    G3J18.75
    G0G40X0Y0
    G0Z100.
    Any help would be much appreciated
    Jun 2015
    4154
    Re: G41/G42 interference
    hy mr5now, each time when i had a problem with a compensation code, i have calculated the coordinates, then i went back to the machine, and checked if the machine is outputing those coordinates
    error is a line before g41, thus there may be a problem with comp lead-in movement : try to increase the clearence, like at least 5-10 x tool dia; if this does not work, then check the toolpath
    why do you repeat G3J18.75 in G90 mode ? kindly
    Dec 2008
    3109
    You are missing a start point in the 2nd contour after changing to G55
    ... if it is the same hole, delete the G55
    ... if is on a 2nd part, add a G0XY after the G55
    just noticed.... you are missing the same on the 1st contour
    you seem to have been lucky that any worked
    Apr 2020
    4
    I'll try your suggestion
    G54 and G55 is used because there are 2 different positions/holes
    Dec 2008
    3109
    Scrap my last post.... I just read your code better
    Queries...
    what value do you have for tool radius (D8) ?
    ... must be smaller than 18.75
    single step thru your program so it won't look/read ahead.... it would error closer to the offending line
    ... how does the program go if D8=0 ? (with tool out of the spindle)
    Apr 2020
    4
    I'll give it a try
    I also tried the G0XY that gives a macro error, i also tried G0X0Y0 which doesnt help with the G41/G42 error (which i didn't think it would)
    Apr 2020
    4
    This is how my entire code looks like now:
    ****(ARTIKELNR: *****)
    (2020-04-14)(Status: Not done)
    (MrSnow)
    G17G21G40G80
    G10G90L2P1X115.088Y-142.636Z-352.926(G54)
    G10G90L2P2X115.069Y-257.757Z-360.893(G55)
    G10G90L2P6X490.Y-188.(DOCKNING ROBOT)
    G30G0G91G49Z0
    /M98P50(ROBOT LADDNING)
    T10M6(PINNEFRES 20.0)
    M11
    G30G0G91Z0
    G0G90G54X0Y0B180(Roterer chuck)
    M10
    (Fresing)
    M3S15000(Freser ut innervegg)
    G54
    G43H10G0Z0.
    G1Z1.F5000
    G41X0Y-21.5F2000D10
    G3J21.5Z-0
    G3J21.5Z-2.50
    G3J21.5Z-5
    G3J21.5Z-7.50
    G3J21.5Z-10
    G3J21.5Z-12.50
    G3J21.5Z-15
    G3J21.5Z-17.50
    G3J21.5Z-20
    G3J21.5
    G40G0Y0X0
    M11
    G30G0G91Z0.
    G0G90G55B0.X0Y0.(Roterer Chuck)
    M10
    (Fresing)
    M3S15000(Freser hull gjennom bit)
    G55
    G43H10G0Z25.
    G1Z25.F5000
    G41X0Y-18.75F2000D10
    G3J18.75Z25
    G3J18.75Z22
    G3J18.75Z19
    G3J18.75Z16
    G3J18.75Z13
    G3J18.75
    G40G0Y0X0
    G91G0G30G49Z0.M5
    (Grading)
    T8M6(Radiefraes)
    G55
    M3S8000
    G90G43H8Z23
    G1Z21.9F5000
    G41X0Y-0.8F1600D8
    G3J0.8
    G3J0.8
    G0G40X0Y0
    G91G0G30G49Z0.M5
    M11
    G30G0G91Z0
    G0G90G55X0Y0B180.(Roterer Chuck)
    M10
    (Grading)
    T8M6(Radiefraes)
    G54
    M3S8000
    G90G43H8Z1.
    G1Z-3.4F5000
    G41X0Y-26.5F1600D8
    G3J26.5
    G3J26.5
    G0G40X0Y0
    G91G0G30G49Z0.M5
    (Gjenging)
    T3M6(GANGFREAS 20.0)
    G54
    M3S10000
    G90G43H3Z-15.
    G1Z-20F4500
    G41X0Y-23.9F5000D3
    G3J23.9Z-17.691(STIGNING 2.309)
    G0G40X0Y0
    G1Z-20.F5000
    G41X0Y-23.9F5000D3
    G3J23.9Z-17.691(STIGNING 2.309 REPITISJON)
    G91G0G30G49Z0.M5
    G0G40X0Y0
    M99
    Jun 2015
    4154
    please, why is G3J18.75 repeated twice ? does it cut 2 full circles ?
    i guess that those are not 2
    halves, since there is no XY coordinates / kindly
    Quote Originally Posted by MrSnow View Post
    (MrSnow)
    (Fresing)
    G54
    G43H10G0Z0.
    G1Z1.F5000
    G41X0Y-21.5F2000D10
    G3J21.5Z-0 (There is no I designated. Can not describe an arc without both I and J. Also G3 does not need to be repeated on every line.)
    G3J21.5Z-2.50
    G3J21.5Z-5
    G3J21.5Z-7.50
    G3J21.5Z-10
    G3J21.5Z-12.50
    G3J21.5Z-15
    G3J21.5Z-17.50
    G3J21.5Z-20
    G3J21.5
    G40G0Y0X0
    (Retract out of the hole here before moving on.)
    Remember the radius of your tool has to be smaller then any radius you try to create the whole time cutter comp is on. Including lead in and out arcs if used. If not you'll get an alarm.
    The rest of your code has the same problems as above.
    Do you want this program to repeat continuously? If not, change your M99 to M30.
    M99
    Feb 2022
    12
    G90 G94 G17 G49 G40 G80
    G21
    G28 G91 Z0.
    G90
    T01 M06
    S3308 M03
    G54
    G00 X0 Y0
    G43 Z5. H01
    G90
    Z-12.354
    G01 Z-13.854 F500.
    G41 X-3.782 Y-0.77 D01
    G03 X5. Y0 Z-13.5 I4.357 J0.77 F69.
    Z-12.0 I-5.0 F122.
    X-3.782 Y0.77 Z-11.646 I-4.425 F69.
    G40 G01 X0 Y0 F500.
    G00 Z5.
    G28 G91 Z0.
    G28 G91 X0. Y0.
    M30
    This is software generated program still interference error occured. please give some solution
    I back-plotted this code and it didn't make any sense with the shapes it created.
    How about showing a simple drawing of what you're trying to do. What tool diameter are you wanting to use? This almost looks like you are trying to do 3 axis simultaneous helical path.
    More details offers the chance of more meaningful help.
    15362
    G54
    M3S8000
    G90G43H8Z1.
    G1Z-3.4F5000
    G41X0Y-25.5F1600D8
    G3J25.5
    G3J25.5
    G0G40X0Y0
    M11
    G30G0G91Z0.
    G0G90G55B0.X0Y0.
    M10
    G55
    M3S8000
    G90G43H8Z23.
    G41X0Y-18.75F1600D8
    G3J18.75
    G3J18.75
    G0G40X0Y0
    G0Z100.
    It may be that you don't have a T8 call for that new block of code
    Mactec54
  1. Help with Chuck interference
    By fmlfred in forum CNC Machining Centres
    Last Post: 09-14-2018, 08:34 AM
  2. Electrical Interference
    By kstrauss in forum Tormach Personal CNC Mill
    Last Post: 07-23-2014, 02:23 PM
  3. Interference Issues
    By ross340 in forum PlasmaCam
    Last Post: 10-09-2010, 03:59 PM
  4. BOB's input interference, help please!
    By Walky in forum Controller & Computer Solutions
    Last Post: 08-01-2010, 03:17 AM
  5. Hf Interference
    By Alex S.A in forum Waterjet General Topics
    Last Post: 02-12-2007, 01:05 AM
