586,106 active members*
2,966 visitors online*
    Apr 2020
    DDSM5V5 controller looses steps
    Hello,
    We try to use a DDSM5V5 controller with Mach3 and it looses steps, we tryed with several computers and different operating systems, on the systems with Windows 7 or higher it moves ok, but looses steps, on the one with XP it stops moving at some points, like it looses the USB connection.
    Is there a problem with the controller or the settings on Mach3, we tested it on different machines, and the same errors occur.
    Thank you
    Aug 2013
    6
    Re: DDSM5V5 controller looses steps
    you may need to use stronger power supply or add gearbox to the motors. it used to happen to me when i make the machine move fast.
    does it looses when moving slow?
    i have the same controller for another machine. but lost the plugin for mach3, could you send it to me please?
    the file is ddsm.dll
    i appreciate
    [email protected]
