586,108 active members*
3,149 visitors online*
    Jun 2015
    85
    Running multiple wattage CO2 tubes with a single head?
    I'm working designing & building a new laser cutter & engraver. I would like to run a 60-80W CO2 laser for my engraving and thinner materials with a 130-150W CO2 for cutting my thicker materials (plywood & such). I've seen a lot of gantries with dual heads, but that doubles the mass that needs to be accelerated & decelerated when rastering. It also cuts into the usable reach of each laser head and adds double the alignment/complexity.
    I'm wondering if there are any beam combiners, like a one-way mirror, that would work with lasers of the same frequency? I've seen dichroic-mirrors/beam-combiners for lasers of different frequencies (usually for adding a red-dot or such).
    Given that the physics of the problem seems unlikely to work out, is there maybe another combination of lasers for marking & cutting that could be combined without drastically increasing the cost?
    Thanks for your input.
    Nov 2010
    787
    Re: Running multiple wattage CO2 tubes with a single head?
    Quote Originally Posted by n1tr0 View Post
    Look. Two Synrad resonators optically combined in one laser.
    CNC lasers, constructions, service
    Nov 2015
    371
    You are right. Having 2 heads is fine for machine designed exclusively for cutting (low speed). However this should be avoided in universal configurations for cutting/engraving especially if you are going to drive the gantry with steppers (steppers loose torque with speed increase).
    Using a beam combiner is the right approach. Combining 2 CO2 beams shouldn't be a problem. There are machines that combine CO2 with Fiber. Check this - Link
    One note - for good quality engraving you want to minimize the beam power fluctuation as much as possible. I assume both of the lasers in your configuration would be DC (Direct Current). For better result I would advise using 40W and below. For DC lasers lower wattage means lower fluctuation as well.
  1. Multiple power supplies vs single for steppers
    By chemsolder in forum Stepper Motors / Drives
    Last Post: 04-15-2020, 02:49 AM
  2. In your experience, are higher wattage tube less stable?
    By siliconghost in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 10-04-2018, 05:34 PM
  3. Multiple CNC Routers With Single Computer?
    By Mahonroy in forum Chinese Machines
    Last Post: 03-06-2017, 02:23 AM
  4. Multiple Tools in single toolpath
    By 9r2a5m70 in forum MadCAM
    Last Post: 04-19-2016, 04:00 PM
  5. Thread milling with single or multiple inserts?
    By magneto259 in forum MetalWork Discussion
    Last Post: 04-12-2007, 04:39 PM
