586,075 active members*
4,151 visitors online*
Results 1 to 7 of 7
    Jun 2014
    1780
    PP backlash settings
    Does anyone know what the syntax is for setting the backlash for X, Y, Z in Pathpilot?
    I can get the line that says admin_set_backlash, but what does one enter from there, every entry I have tried doesnt work.
    any help appreciated!
    mike sr
    May 2008
    667
    Re: PP backlash settings
    Usa at your own risk, never tried this
    Jun 2014
    1780
    Quote Originally Posted by jeffrey001 View Post
    https://www.youtube.com/watch?time_c...ature=emb_logo
    That used to work, now they have in 2.4.3 an admin setting for that, I have tried, but cant get it to work.
    thanks for the reply
    mike sr
    Jul 2018
    38
    I'm not at my mill at the moment but I recall it being something like:
    Code:
    admin_set_backlash x 0.005
    You have ot specify the axis and unit after the admin command.
    This is a very nice change because it allowed backlash tuning without "reloading" PathPilot so it saved a lot of time.
    Jun 2014
    1780
    Thanks, I will try it...
    Quote Originally Posted by Snecx View Post
    Code:
    mike sr
    Apr 2013
    1788
    I just installed 2.4.3 and "admin set_axis_backlash x 0.005" appears to work. You get a message saying that the command was accepted when you spell everything correctly!
    If you screw it up there is a "admin reset_axis_backlash" to undo the changes.
    Any idea what "set_axis_scale_factor" does?
    Jun 2014
    1780
    I havent got a clue what that scale factor does??
    I finally got it figured out, I wasnt typing in the command, I was selecting it from the admin menu, that doesnt work!!
    My X Y axes have .003 and .0028 lost motion in them, the X is smooth, the Y sounds/feels "gritty" evidently at some point it wasnt oiling well.
    I called Tormach, got a nice lady immediately, after telling her my problem in detail I was assigned a case number for a callback, so much for her being a Tech...........
    I think maybe I need to be looking for a ballscrew repair facility ?? The last time I tried backlash settings it left witness marks in the part.
    thanks for the help!
    Quote Originally Posted by kstrauss View Post
    mike sr
  1. Backlash settings for Mach3
    By eman5oh in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-27-2014, 01:58 AM
  2. Wrong Settings, backlash or something else?
    By racedirector in forum DIY CNC Router Table Machines
    Last Post: 06-12-2012, 01:58 PM
  3. Spiral anti-backlash couplers introducing backlash!
    By MArruda in forum DIY CNC Router Table Machines
    Last Post: 06-07-2011, 08:31 AM
  4. Mach 3 backlash settings
    By Rainman229 in forum Mach Mill
    Last Post: 04-01-2008, 09:47 PM
  5. Replies: 8
    Last Post: 03-10-2008, 09:35 PM
